Old 05-12-2014, 09:47 PM
Ron Sutton's Avatar
Ron, question.... what makes AP's 2 offerings "not compatible with other fluids"?
That's a great question. I don't know the answer. AP says it won't mix well with other fluids.
Ron Sutton Race Technology
Old 05-12-2014, 10:11 PM
Che70velle's Avatar
I ran AP in my race cars, but I didn't know you couldn't mix with other brands...but then again I would never consider mixing brands.
Good info Ron. I had very similar results with my late model cars brake temps.
Thanks Dad!!
Old 05-13-2014, 12:44 AM
Originally Posted by Ron Sutton View Post
Just sayin'
Ha. I liked it actually.
Those dang Euros. Can't trust em.
Old 05-13-2014, 01:28 AM
Motul 660
Castrol SRF is crazy expensive, but is the best at resisting moisture saturation. This is the best brake fluid for guys that don’t want to change it as often & can justify the price. You can see this in the chart below … Castrol SRF has the highest rated wet boiling point.
I priced shopped and found the Castrol SRF to only be a little more expensive than Motul 660 on a per unit basis. Thinking of trying one of those based on your reviews Ron.
Thanks!
Old 05-13-2014, 08:01 AM
Track Junky's Avatar
Castro SPF is a bit spendy but defintely looks like a good choice.
Gaetano Cosentino
Old 05-13-2014, 08:13 AM
Unless you actually KNOW your temps -- it seems to be a waste of money if your temps are nowhere close to where this is rated.
Not much point in spending money on fluid that can withstand 600* if you only ever see 350...
My big take-away from discussions like this -- is that from now on I'll take readings of the brakes at the tracks we run -- and I'll make sure my fluid is correct for the application.
Old 05-13-2014, 08:23 AM
Good point Greg but since I've swithed to the Motul I haven't experienced any brake fade. The motto, "if it aint't broke no need to fix it " comes to mind.
Gaetano Cosentino
Old 05-13-2014, 09:05 AM
HAULNSS's Avatar
HAULNSS HAULNSS is offline
Thumbs up
When I tracked my car, I used to run the ATE blue and regular, alternating each time I flushed as it made it easy to see when the 'new' fluid was coming through. The ATE seemed to be a decent price for what I needed it to do.
Randy
1995 Impala SS
T56 Six Speed, Wilwoods, Tri-y's,...
1964 Riviera
31k miles
Old 05-13-2014, 03:29 PM
Well since Greg is pretty much faster than you at T-Hill, I will go with what he is using to start out.
Old 05-13-2014, 03:53 PM
...... and that's when the fight broke out!
Motul 600 because as we dial the car in and I figure out what is "wonky" with my brakes on the Mustang --- and I start running 2.05's the brakes will be worked more - thus bringing up the temps.
