Old 07-21-2014, 10:44 AM
Ron Sutton's Avatar
Love the C&R radiator with built in P/S cooler & heat exchanger for the oil.
Ron Sutton Race Technology
Old 07-21-2014, 01:35 PM
Originally Posted by Rybar View Post
Dave haven't been on a lot last few months, car is looking good I hope you get it back on the road again soon.
Thanks man! Stick around here a little more.. and hey if Ron can get his car running, that gives any man hope.
It's a very sweet piece and C&R just makes great stuff.
Old 07-21-2014, 06:23 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Looks exceptional Brett.
Thanks for posting those progress pics.
^^What Skip said. Looks great!
Old 07-21-2014, 11:42 PM
efs69's Avatar
efs69 efs69 is offline
Great progress on a killer car
Old 07-22-2014, 12:43 AM
byndbad914's Avatar
byndbad914 byndbad914 is offline
Making some good progress!
Having a hard time getting a good angle on this tie rod relocation but on the surface I am digging how that pick up point has been moved down inline with the lower A and appears to be moved in a bit to align with the lower ball joint. Assuming the rack gets put in the right spot relative to the lower A that should seriously fix the bumpsteer mess I am finding with the stock Vette spindles. Do those arms bolt on inline with the three hub bolts? If so, do they clock to the counterbores in some way to ensure the bolts stay centered on the threads? Not a big deal, just for personal info, as I have been considering making my own bolt on arm using those three bolts and just getting longer fasteners, tho' I would need to bore out the centers so my CVs could fit thru on the rear...
sorry, also, who makes that bolt on piece?
Old 07-22-2014, 07:26 AM
That's BAD A$$ right there!
Old 07-22-2014, 01:50 PM
Payton King's Avatar
Hey Tim
Dave asked me to put more random stuff on his thread, but since this is car related, I may have to find pictures of kittens.
Jake had the arms milled. He now builds them out of DOM. For the most part they are the same location as the C5 as to retain the same Akerman. They are moved down because the rack is moved down for packaging on that subframe and to keep the bump at zero. They bolt to 2 of the holes on the hub and one on the upright itself.
Blue Mustang Ron (Good Ron) has the same subframe in his AMX, but moved the motor back far enough as to run the rack in the stock Corvette location and is running the uprights as cast from GM. Same concept you are using from your build photos, not sure why you are having bump problems unless the pivot points on your rack are different than on your LCA.
Old 07-22-2014, 03:06 PM
fleetus macmullitz's Avatar
...or kill 2 birds with one pic.
Old 07-23-2014, 12:37 AM
By bolt on piece if you mean the brake spindle duct plates, those are from LG Motorsports.
Payton knows the long arm JRS setup inside and out (for better or worse) and much more than I do. I do have him beat in the kitten department I am certain.
Your car is coming together nicely Tim. Payton and I will load up and meet you in the middle of USA one day.
Hey Tim
Hopefully the most Bad A$$ on my street anyway.
Old 07-23-2014, 01:36 AM
Nick.V70's Avatar
Nick.V70 Nick.V70 is offline
DAMN!!! I have missed alot of updates on this car...
I remember when it was said the other one got out of control and this one was to be a car you can beat on..... I guess you are going with going out of control and beatable at the same time.
Nick's 1970 Chevelle project - '70 SBC 383 Stroker - Rushforth Rated X wheels - 14" Wilwood - Anvil Carbon Fiber hood/deck lid - Fesler billet - Corbeau Sport Seats, and still building....
YouTube & Chevelle pics - Instagram @nick.v70 & @ChevelleFactory
