Old 07-24-2014, 01:44 PM
Chassisworks Chassisworks is offline
Supporting Vendor
Originally Posted by MoparCar View Post
Very nice. This will also work with your universal weld in crossmember also correct? Same track width as your normal spindle?
Yes, it will also work with the crossmember systems; we make them in 15 different widths with adjusted geometry. The track width is slightly wider than what the corresponding crossmember width would normally dictate. This helps in the pursuit of greatly improved geometry and handling.
Originally Posted by Ron Sutton View Post
That is nice! Chris Alston has always designed top notch stuff, but he may have outdone himself here.
This is no warmed over C6 spindle copy. This is a scratch built spindle with all the tricks. I got a sneak peek at the bearing design & size. They're super strong.
Thanks Ron! The first ones have already shipped to some very excited customers.
Originally Posted by Payton King View Post
Very nice!
Is this a direct replacement for a C5/C6 upright? Will the hub/bearing pack bolt into a stock C5/C6 upright?
This version is not a Corvette replacement; this is a completely proprietary piece. It fits all our bolt-on front clips and a-arm crossmembers. We are using a larger bearing with higher load capacity that does not fit the C5/C6 upright.
We are considering a version of this upright that will fit Corvettes. No ETA is available for the Corvette version.
I think you posted the ladies menu cause I don't see a price.
Pricing for individual components is up on the website HERE. It does not reflect the package pricing when purchasing the whole kit 'n' kaboodle.
Old 07-24-2014, 07:50 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Is this a sealed bearing unit? What does this upright/bearing unit weigh?
Thanks, Jay
Old 07-25-2014, 08:30 AM
Supporting Vendor
Bangshift had some kind words to say yesterday. They included the word 'drool' so I think they really like it.
http://bangshift.com/bangshiftapex/b...-chassisworks/
Thanks, Jay
Yes, it's a sealed bearing. I don't have access to weights at the moment.
Old 07-25-2014, 04:35 PM
Very cool, and I think it is impressive that you can offer such quality pieces at a reasonable price, I know it is not easy....
Old 07-25-2014, 09:08 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Carl, I cannot recall will these bolt up in place of the sculpted spindle or do other components have to be changed out as well? I already have the 6P Wilwoods.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 07-26-2014, 05:27 AM
Rick D's Avatar
Rick D Rick D is offline
Thanks Carl I just spent the last hour going over everything you have for a 2nd gen Very nice!!!
And then of coarse
Rick
Old 07-26-2014, 12:26 PM
parsonsj parsonsj is offline
OK, I'm paying attention now...
John Parsons
Old 07-28-2014, 02:39 PM
Supporting Vendor
It is designed to work with the wider track a-arms so you would need to change those too. Brakes are different too for a variety of reasons. The parts you would remove are compatible with the current Street Machine suspension series, so they could be easily cycled onto another project.
And then of coarse
Old 08-01-2014, 11:58 AM
Supporting Vendor
Here's a behind-the-scenes picture of our new gStreet billet aluminum upright. In this pic you can see three phases of machining process: raw billet, first operation, and final operation.
