Old 07-24-2014, 09:49 PM
fishface's Avatar
fishface fishface is offline
Default accy drive on the cheap
Hi all, still in the planning and shopping mode for my swap and looking at different options for accessories. There is some serious nice looking stuff out there but can't see myself paying $2500-$3000. Wondering how many people have built their own. Considering a corvette drive with the Holley brackets with a twist. Looking at powder coating brackets and possibly switching out some components such as ac compressor, alt, water pump with chrome units from Tuff Stuff or is there better? Anyway, if my numbers are right I think I can come up with a functional and nice looking drive for about half of the aftermarket systems and leave enough $$$ to go elsewhere. Any thoughts on this? If you have done something similar and have a pic would be great.
Old 07-25-2014, 07:46 AM
67Rally's Avatar
67Rally 67Rally is offline
I got my brackets from lsbrackets.com, and bought the accessories seperately: http://lsbrackets.com/. I used the truck accessory brackets here: http://lsbrackets.com/ls-trucksuv-al...umber-ls-0203/ and the pics of the engine with the air cleaner are of mine. Pretty easy guy to work with, and very responsive to e-mails.
Another options is that Pace Performance sells a bunch of different complete LS Accessory Drive kits for LS engines: http://paceperformance.com/c-142691-...rive-kits.html
Old 07-25-2014, 09:39 AM
jwcarguy jwcarguy is offline
Banned
This seems to be a common issue with the vast majority of people building their cars
While the aftermarket accessory drive setups are top notch quality, are more "compact" in their design, I have found over the years that there is a greater number of car builders that don't have approx $2300-$3000 in the build budget, to shell out just on a accessory drive kit
Again, the aftermarket kits are very nice parts, but they do have their draw backs
ie. alot of us building these cars are doing so with the intentions of driving the hell out of them, putting many miles on them and going on road trips with them, not just a "track car" or show car, getting there on the back of a trailer.
The main benefit to using the GM accessory drive kits, is that if you are on the road with your better half and unfortunately breakdown due to any type of part failure (ie waterpump, alternator, p/s pump, tensioner, etc) you can easily go to any of the local auto parts stores, buy a replacement parts, and be back on the road
With the aftermarket kits, most use specific designed water pumps, alternators, tensioners and p/s pumps all that may or may not be readily available "on the shelf" without it being a special order and a few days out to get the part in to your location
We are going to be using this GM kit and a/c compressor relocation bracket on SpiffaV8's 67' Camaro build that I am working on
http://www.jegs.com/i/Chevrolet-Perf...57325/10002/-1
http://www.kwikperf.com/lsx_ac.html
search on Ebay or other sites and you can easily find "new take off" Corvette balancers approx $75 and water pumps for $100 from crate engines
that puts you into a complete GM accessory drive (Sanden compressor comes with A/C system ordered) for approx $900+ (approx $700 if no a/c)
here is a pic of my personal 68' Camaro w/ Corvette access drive kit
hope this helps,
Jeff
Old 07-25-2014, 11:07 AM
spacepirate spacepirate is offline
Awesome info. I'm in the same boat.
Old 07-25-2014, 11:34 AM
67Rally's Avatar
A buddy of mine on TeamCamaro just did an LQ9 in his 69 Camaro, but changed over to the car accessory instead of the truck spacing. He used this one from Pace which includes everything for a non-A/C car and is $528: http://paceperformance.com/i-6485405...7-engines.html
Here's the same one, but for AC for $789: http://paceperformance.com/i-6255430...7-engines.html
Old 07-25-2014, 11:44 AM
Ron in SoCal's Avatar
Rally I used the same one (non-ac) on a buddy's car. Fit was fine and the price has gone down over the last couple of years. IIRC, you need to supply your own balancer and water pump.
I also have one on my garage for the next adventure
Ron in SoCal
69 Camaro in progress
