Old 07-27-2014, 04:13 PM
jeeper90 jeeper90 is offline
Originally Posted by Snipe00 View Post
Check out this book. I plan on doing the swap in future so i bought this to read through.
Is this book worth buying?
Old 07-30-2014, 08:00 AM
rickpaw rickpaw is offline
Originally Posted by 69lsvert View Post
Going back with stock console that has gauges in it and stock dash that a tic tock tach.
You also need to address the gauges hook up as well, especially the speedo/tach The stock mechanical speedo won't work with the electrical output from the ECU/trans, so you'll need some kind of converter.
I took the easy route and went with Dakota Digital's VHX gauge set up.
Tu Ho
Old 07-30-2014, 08:11 AM
OBeer-WAN-Kenobi's Avatar
Me too. Just connected the wires and ran the setup on the fuel gauge, tach and speedometer. After that, working gauges. (I had a bad brain box the first go around but Dakota took care of it and second one worked flawlessly).
You'll need an OBDII port to wire in as well.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 07-30-2014, 09:02 AM
69lsvert 69lsvert is offline
Does the Dakota gauges have the console gauge setup like the tach and speedo?
Old 07-30-2014, 09:05 AM
Also what transmission mount did you go with for the t56? Prothane looks good. I have the Holley crossmember.
Old 07-30-2014, 10:07 AM
I got these:
http://www.dakotadigital.com/index.c...rod/prd722.htm
You also have a choice to get the ones set up for console gauges:
http://www.dakotadigital.com/index.c...rod/prd849.htm
Or you can get the all digital stuff. Personally I don't like the looks:
http://www.dakotadigital.com/index.c...rod/prd166.htm
'69 RS Camaro
Old 07-30-2014, 11:18 AM
Originally Posted by OBeer-WAN-Kenobi View Post
I got these:
x1. Unless you're dead set on original look.
Tu Ho
Old 07-30-2014, 01:00 PM
MaxHarvard's Avatar
I say it is, but i'm a bit bias
Old 07-30-2014, 09:30 PM
Carbo Carbo is offline
Just got my LS and will be starting my swap in the next six months. Still doing homework so I'm paying attention to this thread. Keep the info coming.
Old 07-31-2014, 12:53 AM
Guys that are thinking about ordering Holley ls/t56 swap, the one I ordered didn't come with trans mount and you have to use a clamshell mount off a 73 camaro. I ordered mine from Summit or probably go to your local auto parts store and get them.
Motor and Trans are going in Saturday so I'll try and post some pics.
