Originally Posted by blu72nova
Killer ride Jeff. I hope you don't mind if i try to put some of your ideas to good use. Did you move your rear frame rail up and in? Is that what I'm seeing just inside the tubs where the rear seat would be. I widened my tubs about half an inch and then cut further in to the frame rail Can you speak a little more on how your wheel house modifications have given you extra room? is it at the edges that you were concerned about width? I've got 14.5" of space across 70% of my wheel well. Thanks Shannon
Shannon,
We did trim the frame back a bit more than the directions show to flatten that area of the tub (also plated the back side of frame to give strength), also formed front inside leading edge to allow a little more room in those corners. On the right side, the DSE panhard bracket protrudes into wheelhouse area (see pic earlier in the thread)...that was flushed and replated (this area was REALLY tight to wheel/tire and would have interfered). Basically once you make your initial fit of the tubs, you will see the areas that reduce the space, in most areas you can trim and fit to make them better. The REAL gain is the outer tub, if you are going to lower the car to the height I have mine, the tire will not fit and fully articulate with the factory tub...the radius is too low and flat where it meets the quarter panel.
R/
Jeff
