Old 09-20-2014, 04:48 AM
Rick D's Avatar
Rick D Rick D is offline
Nice progress Joe!!
Rick
Old 09-20-2014, 06:40 AM
torino420's Avatar
torino420 torino420 is offline
Great work Joe! How do you like that front suspension?
69 Torino GT Formal Roof
420" Windsor TKO600
Old 09-20-2014, 07:05 AM
Joe,
As long as you get this altogether before ROB... I'm a happy guy! It's really satisfying to see stuff turn out well isn't it?!? The comparison pic of the rear end before and after is "WOW". Nice filler addition too!
Old 09-22-2014, 05:59 AM
jarhead's Avatar
jarhead jarhead is offline
Thanks guys
Rob, I took my wife for a ride in it yesterday and as soon as we got back I remembered the video that I forgot. It was getting dark and I still dont have the headlights installed.
Jason it rides real nice, sits real low, one of those big a$$ tires on the right front rubs when I turn too sharp.
Here is the mod I finished yesterday in preperation for the scoop, and I got rid of the cheap chrome valve covers.
joe
Semper Fi
My 68 Torino
Old 09-25-2014, 06:52 PM
jarhead's Avatar
Deciding on a location for the Cyclone scoop, and prepping it. It was boogered up and needed glass in the corners, and holes filled.
Had to cut a hole in the hood a few inches smaller than the seal.
joe
Semper Fi
My 68 Torino
Old 11-18-2014, 09:29 AM
jarhead's Avatar
I made a tunnel cover out of fiberglass for the TKO since I am not so good on the "english wheel"
Has some more cleanup work and it will be ready to go
Started working on the Ram Air inlet modifications to the inside of the hood. I had to cut out some bracing, form a ring from 18 gauge, weld it back in to strengthen the bracing, etc.
Working on the outside of the hood now,it was dented up, and fixing the glass on the Cyclone scoop.
An took it out for a test drive, don't have enough miles on the TKO to do an all out "smoke the tires" burn out, but was able to do a rolling burnout, and chirp second!
http://vid144.photobucket.com/albums...psrpwxt3xz.mp4
joe
Semper Fi
My 68 Torino
Old 02-20-2015, 10:42 AM
jarhead's Avatar
Wheels and Tires....
Got a MINT set of these from Dave (nopants68) for Kasey's 63 and she snubbed her nose at them. I was like they would be cool on your car, she said no thanks, so I am putting them on mine.
Need some steelies, but can only find these...
http://www.summitracing.com/parts/wv...2518/overview/
From previous conversation FE Torino said
"In the rear your tire is the same height as my 345 30 19 so it will tuck in and fill your wheel well really nice. FYI without tubs and with about 5.75" to 6" of BS you can fit a 285 tire on the rear of your car with the leaf springs.
Up front the shape of the fender lip makes it difficult to slam the car and get a good turning radius with a wide tire. Typically most tires on the front of the cars you see on here are 25.5" to 26" tall.
With your GW stuff I bet you can drop the front about 2" and still get decent turn radius with a 27" tall tire at 235mm wide, if the BS on the wheels is right. The taller tire will actually tuck up farther in the fender and give a more lowered look.
AND
A 285 fits out back with leaf springs and no tubs I did a 285 17 on teh rear of mine for the first time around. I think a 275 40 18 for the rear and a 255 35/40 18 for the front on 18x10s. That's 25"/26" tall front and 26.5" tall rear. They will fill the wheel wells up. I had a 245 on a 8.5" wheel up front with my shock tower suspension so I'm sure you can fit the 255 as long as the car isn't super slammed.
Currently have 235-60-16
Going for this look
This 68 pictured has 17 x 9's all around. 245/45's up front and 275/40's in the back
With that said will a 285 fit on a 9" wheel?
I currently have 5" backspace on my Cragar's, and what do I make of this offset calc?
Backspacing (in):5.125 in.
Offset:+3.00mm
Thanks, Joe
joe
Semper Fi
My 68 Torino
Old 02-21-2015, 06:42 AM
67TXStang 67TXStang is offline
Originally Posted by jarhead View Post
I really like the way your hood and scoop is turning out. I was just thinking of coming up with something similar for my '67 Mustang. Is the part you have installed around the air filter with the seal a stock part?
Old 02-21-2015, 07:52 AM
jarhead's Avatar
Thanks, it keeps evolving
I bought the aftermarket ram-air from James on the Torino Cobra forum. I bought the lid from Semo Mustang, and a WIX filter. James allows you to delete things you don't need.
He has his own website with different versions. It's a blow molded injection part . I sanded, primed, wet sanded, painted, repeat, rinse, on mine
http://fastlaneinnovations.com/
Joe
joe
Semper Fi
My 68 Torino
