Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Roadster Shop Chassis and Components
Old 11-29-2013, 06:55 PM
preston preston is offline
Looks good.
I know this particular build is a convertible, but often see you and other builders smoothing out the cowls and getting rid of fresh air. I also see most of the Vintage Air A/C setups that don't use OEM design only pull interior air. It has been my experience that while that is great for hot days when you need maximum cooling and drying, having no fresh air into the cabin makes it kind of stale and also makes defrost more difficult (although of course you have the A/C helping). Is this a bit of a sacrifice for looks or is it a total non-issue to have no fresh air source for the interior when you have A/C ?
Old 11-30-2013, 08:20 PM
65 347's Avatar
65 347 65 347 is offline
WOW!!
Old 12-04-2013, 12:14 PM
andreb's Avatar
andreb andreb is offline
Just amazing! Every tweak and mod compliments the next.
Old 06-05-2014, 09:28 AM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Picking up where we left off, attention turned to the way the glass will be mounted and the side vents. For a cleaner, contemporary look, we will be eliminating the vent function and installing a fixed side piece.
With the new quarters going on, the new sheetmetal created a lot of 'compatibility' issues with the roof and top mechanism, part of which meant new handmade trim and sheetmetal massaging in the surrounding area.
Note the rounded corners on the decklid also...
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
Old 06-05-2014, 09:38 AM
NOPANTS68 NOPANTS68 is offline
That rim around the top's edges is just killer. It really finishes off that border and the swept lines and curves match the quarter's radii. Really nice job guys. wow
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 06-05-2014, 09:46 AM
RS-Chris's Avatar
Supporting Vendor
Engine installed and fabrication of the aesthetic pieces:
[/url]
[/url]
We are also going to be machining a new supercharger cover:
Speaking of machining, we also cut the new tips for the exhaust and mounted them:
Old 06-05-2014, 09:59 AM
EBMC's Avatar
EBMC EBMC is offline
Nice job guys!
Steve Keefer
Old 06-05-2014, 11:02 AM
67XR7's Avatar
67XR7 67XR7 is offline
I know this the 589th time i've said this but: GREAT JOB ROADSTER SHOP!!
1965 Chevelle, Pm me if interested in wheel tool rental
Old 06-05-2014, 11:31 AM
RS-Chris's Avatar
Supporting Vendor
Mockup of console location and trim layout.
iPad Mini retracts into dash on a linear actuator.
Couple of shots on the ground as it was moving to have the exhaust built.(wheels are just rollers - we will be making a custom set)
Exhaust detail:
Old 06-05-2014, 11:37 AM
Juggernaut Juggernaut is offline
That's so hot! I'd dreamed about doing a custom center console in my '96 Caprice before it was totaled but never got around to it.
Gonna re-read this entire thread after work tonight!
