Old 11-04-2014, 02:27 PM
What's the approx power level here?
Old 11-04-2014, 02:47 PM
carbuff's Avatar
carbuff carbuff is offline
^ this...
I wouldn't worry about sacrificing 10-20HP in a car if it's going to mean a big headache. It may sound sacrilegious given how much time we spend talking about how to make HP. But when you are driving it, unless you are fighting for that last tenth in some kind of race, you will be a lot happier to have a cleaner/no-clearance-problem solution. Heck, I've been driving my car for a year now without getting it on a dyno to try and tune it for the best HP, and I'm loving having it on the road! (note to self - I need to schedule that dyno session. ).
Old 11-04-2014, 05:19 PM
Should be a 500hp 383 if I get the supporting mods correct. The company that's doing the heads and suggesting the cam said cars are typically in the 420-440rwhp range with the setup I'm going with. The heads flow just under 200cfm max on the exhaust side. I'm looking to redline at 63-6500. All my math tells me I need 1-3/4" headers. While I'm not trying to build a race car, I don't mind trying to do it as best I can so that I can hopefully surprise people that usually look upon LT1s as junk.
Thanks everyone.
Old 11-04-2014, 05:50 PM
Yeah I hear ya Trey. I'd go 1-3/4 and the easiest path, which sounds like the shorter ones from your description. Should be a fun and drivable motor with those numbers.
Old 11-04-2014, 06:28 PM
Thanks Dave. I'm leaning that direction. I figure that so long as I do a good job on them, I should be able to sell them to someone else should I want to try a different design. I believe a big part of making a good header is making it look good and not just function well. So I'll be working on that aspect as well through all of this.
Old 11-04-2014, 08:35 PM
The flat 4 into one collector does not work well on a naturally aspirated car because you lose a lot of the vacuum effect of the exhaust pulse before it. When they are square the pulse before it helps draw the next through, but when they are flat the outside tubes are too far apart. Probably not the best explanation...
You will lose more power with the flat 4 into 1 than if you make long, short or improperly size primaries. If you are supercharged this is less important because you are forcing everything through from the other end.
If it was me, I would consider removing your bracing bars, build the headers the way you want and then see what you need to do to re brace everything. Mind you, I always seem to do what costs too much and takes too long so maybe don't listen to me. Lol
Old 11-05-2014, 09:40 AM
Those were my thoughts on the flat 4 collector as well.
Redoing the brace may be an option. We'll see. I don't mind coming up with neat little fabrication stuff like that.
