Old 11-07-2014, 08:26 AM
esporgi esporgi is offline
Ok so
Big housing end from Moser
http://www.summitracing.com/int/part...00db/overview/
with this kit
http://www.summitracing.com/int/part...9217/overview/
Am I right ?
Old 11-07-2014, 09:48 AM
dontlifttoshift's Avatar
That brake kit is for the 2.36" axle offset so you would need the axles for that. I would use 2.50" axle offset.
Donny
Old 11-07-2014, 09:54 AM
That the think ! Because I don't found any kit with 2.50" offset
Old 11-07-2014, 12:34 PM
Let me look that up for you....on second thought, you can.
www.wilwood.com Search bolt on brake kits by axle flange. There are at least 10 different kits all with options for rotor style/finish and caliper finish.
Donny
