Old 12-05-2014, 07:47 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
As mentioned in the above post, there are three different seat categories.
We'll touch on the Tuning seats here.
One of the most popular is the Sportster CS.
Now I'm not entirely sure why this is, but regular Recaro Sportster CS's are special order only (12-16 weeks). Sportster CS with HEAT are typically a stocking item though. Of course you don't need the heat if you're not driving in the cold months (if you have any), but the CS w/heat also has more material combinations.
This Sportster CS (w/heat) seat is available in the following combinations:
-Black nardo with Artista insert - $1649
(410.10.1351 / 2351)
-Black vinyl with dinimica insert: Black, silver, or red - $1749
(410.10.1575 / 2575 black)
(410.10.1588 / 2588 silver)
(410.10.1585 / 2585 red)
-Full black vinyl - $1649
(410.10.1132 / 2132)
-Full black leather - $2049
(410.10.1785 / 2785)
-Many other special order options available
The Cross Sportster CS is the same as the Sportster, but has lower side bolsters for easier access, or for wider people. Prices are the same as above, also have heat, and the side bolsters look like this:
More info & pictures here: https://www.recaro-automotive.com/us...rtster-cs.html
Next is the Speed. These have an integrated headrest, openings for harnesses, dual back release, and dual side recline levers (left/right are the same). The Speed is NOT available in leather due to the angles of the foam; the leather does not lay nicely.
For you guys who want more safety, this seat is also available with a crotch belt opening but is a different part number.
***The Speed also has an "S" model which has lower side bolsters, but still offer plenty of support;
***And lastly they have the Speed M (New for 2016) which has very low side bolsters like the other Recaro seats with the M suffix.
The Speed S and M are NOT available with the crotch belt opening.
The Speed seat is available in the following combinations:
-Full black Avus, with white/red/blue logo stitching options - $999 ($1059 for crotch belt provision)
*Note: .002 replaces .000 below for the crotch belt provision*
(SPD.00.000.AA11 / .002 -white)
(SPD.00.000.AASF / .002 -red)
(SPD.00.000.AAWL / .002 -blue)
-Black vinyl with AM vinyl insert, silver logo - $1099 ($1149 for crotch belt provision)
(SPD.00.000.YG11 / .002)
The Speed S is available in the following combinations:
-Full black nardo, silver logo - $949
(SPF.00.000.NN11)
-Full black avus, white or red logo options - $949
(SPF.00.000.AA11 -white)
(SPF.00.000.AASF -red)
-Black vinyl with AM vinyl insert, silver logo - $1049
(SPF.00.000.YG11)
-Black AM vinyl with black suede insert, silver logo - $1049
(SPF.00.000.YS11)
-Full black AM vinyl, silver logo - $1049
(SPF.00.000.YY11)
The Speed M is available in the following combinations:
-Full black nardo, silver logo - $1039
(SPW.00.000.NN11)
-Full black avus, white or red logo options - $1039
(SPW.00.000.AA11 -white)
(SPW.00.000.AASF -red)
-Black vinyl with AM vinyl insert, silver logo - $1139
(SPW.00.000.YG11)
-Black AM vinyl with black suede insert, silver logo - $1139
(SPW.00.000.YS11)
-Full black AM vinyl, silver logo - $1139
(SPW.00.000.YY11)
More pictures/info here: https://www.recaro-automotive.com/us...cts/speed.html
Next is the Recaro Sport & Sport Topline.
Here are the features of the Sport & Topline models:
-Manually-adjustable lumbar support: The air chamber inflates and deflates to your desired level of lumbar support. Adjust the lumbar to ergonomically support your lower back and meet your comfort needs.
-Bearing-mounted seat cushion: Built-in shock absorbing system ads unbelievable comfort.
-Shoulder, back and thigh bolsters
-Adjustable backrest
-Integrated head rest: Integrated headrest is designed with belt pass-throughs for 4 point belt harnesses for a sport appearance.
-Dual manual seat back release
-High quality foam padding: The entire seat is lined with thick, dense high quality foam, adding to seats sport feel and ensuring long lasting support.
The Sport Topline is the same, however it features a power back rest adjustment, the heat/vent climate package, and has a leather option.
The Sport seat is available in the following combinations:
-Grey nardo w/grey artista insert - $999
(265.00.NR55 / .10.NR55)
-Full grey nardo - $999
(265.00.NN55 / .10.NN55)
-Black nardo w/black artista insert - $999
(265.00.NR11 / .10.NR11)
-Full black nardo - $999
(265.00.NN11 / .10.NN11)
Black AM vinyl w/red, grey or black suede insert - $1149
(265.00.YS16 / .10.YS16 - Red suede)
(265.00.YS15 / .10.YS15 - Grey suede)
(265.00.YS111 / .10.YS11 - Black suede)
*** .00. -LH side, .10. -RH side ***
The Sport Topline seat is available in the following combinations:
-Grey nardo w/grey artista insert - $1399
(255.00.NR55 / .10.NR55)
-Full grey nardo - $1399
(255.00.NN55 / .10.NN55)
-Black nardo w/black artista insert - $1399
(255.00.NR11 / .10.NR11)
-Full black nardo - $1399
(255.00.NN11 / .10.NN11)
Black AM vinyl w/grey or black suede insert - $1499
(255.00.YS15 / .10.YS15 - Grey suede)
(255.00.YS11 / .10.YS11 - Black suede)
Grey leather w/grey nardo insert - $1649
(255.00.LR95 / .10.LR95)
Black leather w/black artista insert - $1649
(255.00.LR11 / .10.LR11)
Black leather w/black suede insert - $1699
(255.00.LS11 / .10.LS11)
Full black leather - $1699
(255.00.LL11 / .10.LL11)
Last is the Style XL & XL Topline. These have maximum adjustability to suit your body type, and have more of an ergonomic appearance to them, making them perfect for a cruiser. They do not have access for harnesses.
Here are the features of the Style XL:
-Airmatic Lumbar System: Three independently power adjustable air chambers make up the Airmatic Lumbar System
-Adjustable back bolsters
-Manually-adjustable backrest
-Adjustable head rest
-Bearing-mounted seat cushion: Built shock absorbing system ads unbelievable comfort.
-Seat cushion extension: The seat cushion extends to the most comfortable and supportive position for you.
The Style XL Topline model is the same, however it features a power back rest adjustment, and the heat/vent climate package.
The Style XL seat is available in the following combinations:
-Grey nardo w/grey artista insert - $1949
(229.00.1.NR55 / 2.NR55)
-Black nardo w/black artista insert - $1949
(229.00.1.NR11 / 2.NR11)
The Style XL Topline seat is available in the following combinations:
-Grey nardo w/grey artista insert - $2249
(229.41.1.NR55 / 2.NR55)
-Black nardo w/black artista insert - $2249
(229.41.1.NR11 / 2.NR11)
-Full black leather - $2849
(229.41.1.LY11 / 2.LY11)
-Black leather w/black suede insert - $2849
(229.41.1.LS55 / 2.LS55)
More info & pictures here: https://www.recaro-automotive.com/us.../style-xl.html
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
