Old 12-05-2014, 04:15 PM
MattG's Avatar
MattG MattG is offline
Originally Posted by cwylie View Post
Anyone up and running with one of these yet?
I've had mine running for 4 months now and it does a great job. My tuner says it controls inlet temps much better than the stock Magnuson heat exchanger. He was impressed to say the least!
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 12-06-2014, 02:25 PM
cwylie cwylie is offline
Do you have the part number for that vintage air condenser by chance?
Old 12-06-2014, 08:33 PM
Does anyone have pictures of one of these going in or installed? sure would appreciate seeing them..
Old 12-07-2014, 10:23 AM
chassis crafters's Avatar
chassis crafters chassis crafters is offline
hey guys we installed this same unit in the 69 lsa Camaro we done for a customer. and its got to be one of the best pieces we have installed to date .it fits great and accepts vintage air .we use phil cook for are salesman great guy. just ordered one for the 63 vette we are doing with a LSA
Old 12-08-2014, 07:48 PM
What have you all used for a reservoir on these?
Old 12-08-2014, 08:15 PM
snappytravis's Avatar
snappytravis snappytravis is offline
That's the tricky part, I looked and looked, I think a person could use a reservoir out of a magnuson kit for 5th gen Camaro. It is small and mounts to the firewall, I however figured that the more capacity I had for coolant the better it may cool.
So I looked up canton racing and ordered a blem tank( small weld splatter on the aluminum) It is a batter box style tank for a mustang. I built a frame much like a battery box out of 1 inch angle. I mounted it to the radiator support and to the inner fender on the passengers side.
I then went and bought several different length 90 degree bend hoses, say 4 inches, then 14 or 16 or 18. They run down between the tank and radiator and under the radiator support to the front of vehicle where the intercooler pump is mounted. then out of pump into the heat exchanger.
I ordered a pump from lingenfelter it had the harness and everything with it.
Good luck, Hope I helped you out,
https://www.cantonracingproducts.com...5-10-MUSTANGS/
look up gates 28474 hose. You can get a different ones with various lengths, then cut to fit your setup.
Old 12-15-2014, 03:34 PM
How did you all mount the bottom bracket? I noticed they spacers and bolts included with the kit and I assume they want you to drill through the core support but there were no instructions.
