Old 12-15-2014, 03:01 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Originally Posted by LS3torque View Post
On a car that has enough room for long tubes why wouldn't you run long tubes? I know the LS1 2 and 3s have good torque out of the box but why leave torque on the table?
Tom
They published some dyno results, interesting numbers on the LS7:
http://www.ultimateheaders.com/dyno.shtml
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 12-15-2014, 04:09 PM
SlowProgress's Avatar
I have these headers mocked up in my 67 Camaro. I also have the original manual clutch bell crank that came stock with the SS 350. The only problem is that I don't know where the bellcrank would attach to the LS block. If you supply that (some dimensions would be great) then I can mock up the bellcrank and get a photo for you in the next few days. Here is a photo to let you know if it would be similar enough to make a decision.
Old 12-15-2014, 06:36 PM
simbad's68 simbad's68 is offline
Default Ultimate Hedders
What motor mounts are recommended for the first gen using the Ultimate hedders? I paln on running a low mount a/c on my LS3. There's no recommendations on their web site.
Old 12-15-2014, 07:52 PM
Carbo Carbo is offline
Thanks for the offer. However I talked to Jim at Ultimate Headers today and he had one of his techs with him. They said that their headers will not work with a mechanical clutch as the collector runs right near where the z bar would attach to the block.
FYI, if you want to run a mechanical clutch with an LS you have to drill and tap into the block to accept the z bar ball stud. So I guess if I choose Ultimates I have to run a hydraulic clutch. Decisions, decisions.
Old 12-15-2014, 09:05 PM
Jim is really helpful. You know I had a mechanical clutch for all those years and now I am looking forward to running a hydraulic setup. The initial cost is going to be high, but I am looking forward to easy pedal pressure, cleaner install and the more modern designed parts. Funny the grass is always greener I guess. Good luck with your decision !!
Old 12-16-2014, 09:43 AM
Supporting Vendor
If you're running a T56, cost is pretty cheap on an OE style slave/TOB ($120 or so).. and a master cylinder kit isn't that much either, around $300-400.
The TKO is a little different story though.
-Dale
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
Old 12-16-2014, 07:10 PM
Yeah Dale, I've been pricing around for the TKO and it's gonna cost around $700.00, give or take a little. This hobby sure is expensive.
I'm looking to do an external slave rather than a hydro TOB. Novak Conversions has a ES for $208. I may be installing that with a McLeod hydro kit for the same price. I just hate the fact that if I get a leak I have to pull the tranny.
Old 11-18-2017, 10:27 PM
randy randy is offline
Bump. Would like some real experience feed back
