Old 01-17-2015, 11:58 PM
The things that I can see is geometry improvents up front.
Your leafs are fine.
I'd be going after better shocks, fixing the bump steer issue and replace the graphite bushings up front. Tall ball joint or tall spindle will give you ther camber gain. I would look at a spindle cause it will fix two issues.
For your budget you can do a set of Koni reds, Ridetech Tru turn or ATS AFX spindle.
The only issues is you'll have to upgrade your front brakes with the ATS AFX or you may need new headers with the Ride tech Tru turn.
Everything else you listed can do for now.
