Old 01-14-2015, 08:34 AM
Originally Posted by 68LS1 View Post
Where does the position A/C compressor?
Up top, passenger side.
Old 01-14-2015, 12:26 PM
mikels mikels is offline
Originally Posted by dhutton View Post
The Vintage Air Front Runner they sell does not require the notch....
Vintage Air Front Runner will not work with blower drive. LS9 accessory drive packages AC compressor passenger side low. It and generator are driven by one belt (6-rib), while SC, H2O pump, PS pump are driven by 2nd belt (11 rib).
Old 01-16-2015, 05:57 AM
FathomGreen69's Avatar
FathomGreen69 FathomGreen69 is offline
I may have missed it, if so, my apologies, but just how much horsepower and torque was the LS9 makin that wasn't enough?
Old 01-16-2015, 09:05 AM
Sieg's Avatar
Sieg Sieg is offline
This will make it perfectly clear: https://lateral-g.net/forums/show...&postcount=481
Old 01-18-2015, 03:01 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Actually, I recall Jackass at Thomson Automotive last year. Brian told me that Jackass LS9 was getting new CNC LS9 heads and new cam. Interesting to see what was the improvements over the stock LS9.
Jeff
Old 01-18-2015, 03:09 PM
Sparks67's Avatar
Originally Posted by formula88 View Post
Mark pocketed the cross member near the RH engine mount to provide clearance for the AC compressor.
Mark is Sled Alley going to make the changes to LS1 style engine mounts for noise and vibration as Hellfire?
Jeff
Old 01-18-2015, 06:04 PM
youthpastor's Avatar
We've used Concept One A/C compressor mount for the LS9 and it gave us enough clearance
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 01-21-2015, 08:09 AM
Payton King's Avatar
This question is going to seem to come out of left field...what injectors are you running in both Hell Fire and JA 2 ? I am looking for an injector to support 800 hp NA and did not know if the GM injector is up to the task.
I have looked at this injector as well
http://injectordynamics.com/injectors/id850/
Thoughts?
Old 01-21-2015, 08:11 AM
Thoughts?
I'm pretty sure he's using fire hose nozzles. I could be mistaken though.
Old 01-21-2015, 08:34 AM
Payton --- start here.
http://www.witchhunter.com/injectorcalc1.php
