Old 01-30-2015, 09:02 PM
Will get some pics hopefully tomorrow. Aside from needing to SLIGHTLY modify it to let my mount sit down enough to bolt it I think it's a nice piece.
Will mess with it some more to see if I can avoid modifying it. Either way. Worst case will be slot the mounting holes. It fits excellent otherwise.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 01-31-2015, 12:38 PM
randy randy is offline
so plenty of room for the exhaust? Whats the part number?
Old 01-31-2015, 07:29 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
William,
I was looking at that crossmember I think it is Hooker PN 12626HKR but I can't tell for sure how it mounts to the frame rail. Do you have some shots of where it mounts to the subframe on each side? It looks like it mounts on top of the frame rail on one side and the bottom of the frame rail on the other side.
As for trimming the bottom of the bell housing flange. Hold off. I have the same BH and frankly it has not been a problem on Dust Off. I would recommend driving the car a while before cutting it. Once it is cut the BH is no longer SFI certified. Just saying.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 01-31-2015, 07:44 PM
cwylie cwylie is offline
It mounts on the top on both sides in the factory location. I am using the same mount.
Old 02-05-2015, 06:55 AM
Cwylie is correct. Mounts on top of the frame. Part number I am unsure but it's the only one I know of made by holley/hooker.
As for the bellhousing, we'll see. I am aware the sfi certification would be void but I consider that a much lower penalty than what will happen if it snags a bump.
They need some slight modification but not TOO bad.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 02-05-2015, 08:06 PM
rickpaw rickpaw is offline
Car is looking great Will. It was good meeting you the other day.
Tu
Tu Ho
Old 02-05-2015, 11:09 PM
What about building a skid plate for the bell housing? That way you can maintain the cert.
Old 02-06-2015, 06:41 AM
Out of curiosity when am I going to need the cert on my bellhousing? Why so important to keep that?
Good meeting you Tu
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 02-06-2015, 09:42 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Just chewed through 40 pages of this build. Outstanding! Congrats on winning the suspension upgrade also! Subscribed!
Brent
Old 02-06-2015, 09:45 AM
Thanks! It's been going a long time. Wish it was further along but it's getting there. I have a feeling this is the year for this car to finally hit the road!
William
Texas A&M BSME 2008
1992 Corvette ZR-1
