Old 02-12-2015, 08:00 PM
Those brackets are going to make this fan a lot easier to mount. Nice!
Old 02-12-2015, 08:18 PM
parsonsj parsonsj is offline
Originally Posted by Me
In a related question, I'm using the stock ZR1 intercooler (charge coolant) pump and it has a two prong connector (just 12v power and ground). The GMPP LS9 harness has three wires (which are 12V, PWM signal -- J3-42 lt. blue/white, and ground)
The stock ZR1 runs without a PWM-controlled intercooler pump, and the GMPP LS9 harness has a PWM connector for the coolant pump. Why are ZR1 LS9 and the GMPP crate LS9 wired differently in this case?
Any insight or help is much appreciated!
I got some good tech on this over on CorvetteForum: http://www.corvetteforum.com/forums/...mp-wiring.html
John Parsons
Old 02-13-2015, 05:04 PM
andrewb70's Avatar
You got some good tech over there John. Here is a link that might be handy:
http://www.lingenfelter.com/mm5/merc...gory_Code=C534
Lingenfelter makes upgraded coolant pumps that are PWM. Isn't that what you want for this build?
Andrew
Old 02-14-2015, 06:29 AM
Yes, and no. I wanted a PWM installation because I thought that's what GM did with the C6 ZR1. But they didn't -- they just run the pumps at full speed. They even run the pump at full speed in the C7Z06.
My main question was the 3rd wire in the provided GMPP harness -- which I now know is a 5V signal to the ZL1 pump to, you guessed it, run the ZL1 pump at full speed. That wire is not a PWM signal, and there is no PWM option anywhere in the GM lineup, which continues to the present day.
Even the LPE Stewart option just runs at full speed, and is advertised as flowing as well as the ZR1 pump.
So... I'll run the ZR1 pump at full speed. It simplifies the wiring, and wraps up all the engine wiring questions.
John Parsons
Old 02-14-2015, 08:09 AM
130fe 130fe is offline
Is the PWM fan control Function something that can be turned on with HP tuners?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 02-14-2015, 09:18 AM
Edit: Sorry! I thought you were asking about the coolant charge pump. Yep, the fans are easy to do.
John Parsons
Old 02-14-2015, 09:34 AM
samckitt's Avatar
samckitt samckitt is offline
HP Tuner dialog for the GMPP LS2 ECM tune. Others probably different.
Scot
86 Monte SS
LS2/T56 Magnum
Old 02-17-2015, 02:34 PM
samckitt's Avatar
Originally Posted by andrewb70 View Post
Funny...mine showed up today as well. I am sure they are wondering what the heck is going on. C&R probably didn't sell this many all of last year...LOL
Andrew
Hey Andrew, I got the C6 fan that you have. Wondering if you are seeing the same as I am. One of the clips with the hole, the hole doesnt line up with the hole in the fan shroud. You seeing that too?
Scot
86 Monte SS
LS2/T56 Magnum
Old 02-17-2015, 02:38 PM
andrewb70's Avatar
Yes Sir. I noticed that too. I guess I'll slot the hole. Won't be a big deal since you have to use a u-bolt there anyway. I wonder what the stock bolts that go in that location look like. And why is the hole square? LOL
Andrew
Old 02-17-2015, 05:35 PM
samckitt's Avatar
I thought I would use something like this:
Scot
86 Monte SS
LS2/T56 Magnum
