Old 09-08-2006, 06:11 AM
J2SpeedandCustom J2SpeedandCustom is offline
Originally Posted by shineym3
Thanks for letting me know! Do you happen to know what the backspacing is for those wheels? How did your figure out what the maximum turning radius was?
5.25" for my setup. This puts the rim about 3/8" from the steering arm end. The turning radius was easy. Once the car is at ride height you turn the wheel from side to side. The outside wheel well is where the rubbing would be if you didn't limit the amount of turning. We are a 1/4 turn of the steering wheel from full lock so it didn't limit it much.
Jeff Allen
J2 Speed and Custom
Old 09-08-2006, 09:49 AM
shineym3 shineym3 is offline
Default ride height
I am looking for the same stance that X has. What I can't figure out though is why people have said that with a STOCK front subframe 8" is the widest you can go, yet Mark got a 9" under there using the stock subframe with a car that is sitting that low. I am wondering how he was able to do it. Judging by his pervious works he measured everything about a billion times a broke out the slide rule and FOUND the way it would work. So how'd he do it?
Old 09-08-2006, 12:20 PM
camcojb camcojb is online now
Who said he has a 9" wheel up front?
Old 09-08-2006, 12:38 PM
Default Post #62 of the "Camaro X" thread in the Open Discussion forum...
Ryan-
It is indeed mini tubbed with the DSE kit, he is running the 18x9/18x12 combo, with I think a 335 rear Michelin tire.
Steve-
Fikse just released this variation of the Profil 5S for racing, so it has some special features that Mark wanted. I like 'em.
Tyler
Old 09-08-2006, 12:39 PM
Mean 69 Mean 69 is offline
I'm running a 275 on a 9.5" wheel on the front of my 69. In order to do so, you will give up quite a lot of turning radius, there are various rub points from inconvenient all the way up to dangerous if not dealt with appropriately. The best way to prevent over-steering issues is to alter the steering stops on the stock control arms, ala Speedtech's idea. I don't know what the rub points are with a stock upper control arm, I am currently running GW's (but only until our new arms are done later this year...). It's not pretty in many cases, inner fenderwells, had to remove a couple of bolts for the wheelwell chrome trim pieces, etc. Worth it? In my eyes, completely. The added grip is significant, and the look is mean. I don't know what the backspacing is on my car, but it's irrelevant for most folks as I have some one-off custom stuff on the front (brakes, wheelspacer, etc).
Carl Casanova has a write-up on this in his website with a lot of detail, including backspacing etc.
Funny, one of my customer is in the process of buying wheels for his car, and one wheel source told him the very biggest he could run on the front of a 69 is a 7" wheel with a 225 tire. Swore up and down. Crazy.
Mark
Old 09-08-2006, 12:40 PM
Jr's Avatar
Jr Jr is offline
Tyler (ATS) said, "It is indeed mini tubbed with the DSE kit, he is running the 18x9/18x12 combo, with I think a 335 rear Michelin tire". this is post number 62 in the Camaro X thread
Old 09-08-2006, 03:15 PM
Alright here is the deal-
Front rims-
Fikse Profil 5S, 18x9 with 6.125" of BS.
Rear rims-
Fikse Profil 5S, 18x11 with 6.125" of BS
Front suspension mods to make this work-
Upper and Lower DSE control arms, ATS AFX tall spindles, factory Camaro P/S steering arms, Baer bumpsteer adjustable outer tie rod ends with modded bolt and spacers, inner fender well hardware replaced with low profile buttom head screws.
Rear suspension mods-
DSE mini tub kit with Quadralink suspension, narrowed rear end.
Anything else?
Tyler
Old 09-08-2006, 03:29 PM
olds87 olds87 is offline
How the project 50/50 going?
Old 09-08-2006, 05:00 PM
Default tire size?
Tyler,
Is there a certain tire size that you would recommend? Naturally Camaro X has the perfect stance IMHO but I probably won't start of with the quadra-link right off the bat; what would you suggest for a more traditional rear end set up? Thanks for the input!
Old 09-08-2006, 06:47 PM
aonghus's Avatar
aonghus aonghus is offline
Kyle told me at the Del Mar Good Guys that the largest wheel/tire combo that can fit in the rear was 18x11 w/ 5.5" Backspacing.
I think DSE's position is "without modifying anything" aside obviously from the rear housing itself, or the front sheet metal.
