Old 02-24-2015, 02:19 PM
carbuff's Avatar
carbuff carbuff is offline
Not sure I can help, but what is the SPAL part number of the fan which you have? I'm curious to read the installation manual for it...
Old 02-24-2015, 02:31 PM
dontlifttoshift's Avatar
There wasn't much information out there for the SPAL brushless fans a while back. If I remember right, the PWM controller is already built into those fans and are designed to run off of their sending unit.
Donny
Old 02-24-2015, 02:48 PM
erick_e erick_e is offline
Spal 30107035 (VA97-ABL309-98A) 17" brushless fan.
I've tried to look for any information on it, but cannot find very much. I was able to find a few schematics using their temperature sending unit and have the factory schematics, but I'm hoping to be able to use the ECU to control it.
I thought about running it in analog mode using the factory PWM controller, but don't know if that will function as originally designed.
Old 02-25-2015, 06:03 AM
This is the only info I could find on that specific fan.
Old 02-25-2015, 06:41 AM
samckitt's Avatar
samckitt samckitt is offline
In the above circuit diagram, what does this symbol represent:
Scot
86 Monte SS
LS2/T56 Magnum
Old 02-25-2015, 06:58 AM
Male/Female Inline Harness Connector
Old 02-25-2015, 07:13 AM
samckitt's Avatar
Ah, thanks. I didnt know if it was some type of electrical component. First thought was maybe a Diode, but then remembered it was a triangle with a line.
Scot
86 Monte SS
LS2/T56 Magnum
Old 02-25-2015, 07:48 AM
andrewb70's Avatar
It seems that Spal makes various components to make this fan operate in PWM mode without using any sort of ECU, is that right?
Andrew
Old 02-25-2015, 02:39 PM
Andrew
Yes, they make a temperature sensor which controls the fan, but I still want to be able to control it using my ECU and tune.
I had a decent email conversation with SPAL tech support today. He informed me that there are only three wires going to the fan pos/neg/pwm. The yellow analog/override wire shown in the one schematic isn't actually present on the fan and that I need to use their white pwm wire to tell the fan how fast to run.
I told him I had the ability to adjust the pwm frequency and duty cycle in my ECU and he provided me with this response curve, but I still don't know how to make it work.
So now the question is what how do I use their pwm wire with my ECU.
He said 128 Hz should be ok, but if I really want to change it 100Hz would be the optimal.
Can I just change my PWM frequency in my ECU to 100 Hz and connect the green pwm fan controller wire to the white pwm fan wire?
Old 02-25-2015, 02:59 PM
andrewb70's Avatar
What ECU are you using?
Andrew
