Old 03-03-2015, 01:40 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Is the master bled? what about when you push the brake pedal down?
Most like air is trapped inside. I disconnected the flexi lines to rear calipers,pushed the brake pedal down and noticed bubbles inside the master cylinder with the lead off.
Is this the reason why fluid not going through the valve or even through the MC ports while lines to the valve are disconnected?
72 Camaro RS:SOLD
68 Camaro:
