Old 03-24-2015, 05:42 PM
samckitt's Avatar
samckitt samckitt is offline
When my check valve went out it let compressed air out to the atmosphere. You could hear it.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-24-2015, 06:15 PM
Michael ---- GO here and poke around.....
http://www.about-air-compressors.com...ast-30psi.html
Old 03-24-2015, 06:46 PM
Same website - has a check list of things to consider and look for.... seems your issue is very common.
http://www.about-air-compressors.com...-pressure.html
Old 03-24-2015, 07:03 PM
Sonar Chief's Avatar
Thanks for the link ... at least I wasn't holding my breath for an answer from Sears!
Thanks again .... reading time now!
Old 04-28-2015, 10:16 AM
Question Still not working!
Well, this is frustrating as hell! After I replaced the pistons and cylinders, new gasket it would make about 35psi. Hmmm... bought the plates or "heads" which contain the intake and exhaust reeds, replaced them and the gauge, still running forever and never gets past 35psi, what the halibut?
Forums and emails have not helped much as I have replaced everything mechanical, the electric motor is not running hot (as it would if it lost one 120 vac line) ... so?
If anyone needs a 275 paper weight let me know! jk
I still need to get this fixed so I can keep using my air tools!
Any other suggestions?
Thanks again,
Michael
Old 04-28-2015, 12:06 PM
dhutton dhutton is offline
Thanks again,
Michael
Is the unloader valve stuck partly open?
Old 04-28-2015, 03:49 PM
Unloader valve information here:
http://fix-my-compressor.com/air-con...nloader-valve/
Old 04-28-2015, 07:31 PM
Question
I don't believe so ... the tank is holding pressure! It makes so much noise when its running, I can't hear any leaks though.
I even replaced the check valve, there was nothing wrong with the OEM thou!
Got me ....
