Old 03-27-2015, 01:09 PM
parsonsj parsonsj is offline
Originally Posted by Vince
Yes, there should be an AC input wire right? Let me see if I can find the pin #
On the E67, the A/C request signal is via CAN request from the BCM, not a signal wire.
John Parsons
Old 03-27-2015, 01:38 PM
ECM fan request pins are a grounding circuit right?
Old 03-28-2015, 12:54 PM
samckitt's Avatar
samckitt samckitt is offline
So with the GMPP controller (I believe it is an E67), there is no point adding the AC pressure sensor/switch? Unless the BCM is added?
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-28-2015, 01:21 PM
It would be better if the A/C request went through the ECM so we could have compressor protection features (like RPM limit, WOT cutoff, overheating protection, etc.). But we don't, so all we get are fan control features via the A/C pressure sensor. Is it worth doing? I think so, but it isn't ideal, and the system needs a binary switch to protect the compressor since the ECM doesn't/can't.
If only Vintage Air or InfinityBox (nee ISIS) had support for GM's A/C CAN-bus request...
John Parsons
Old 03-31-2015, 06:19 PM
samckitt's Avatar
Fits like it was made to go there. LOL
Scot
86 Monte SS
LS2/T56 Magnum
Old 04-30-2015, 11:29 AM
samckitt's Avatar
Anyone else looking for one of these connector bodies for the PWM fan module? If so I will order a few more.
Scot
86 Monte SS
LS2/T56 Magnum
Old 04-30-2015, 12:35 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
So what options does one have for integrating with an aftermarket ECM like in my case a FAST XFI? The FAST XFI ECM only has a negative relay control for fan on/off. I was reading about the Derale PWM controller but not a fan of the push in probe. Other options for a stand alone PWM?
http://derale.com/products/electric-...n-probe-detail
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 05-03-2015, 01:28 PM
65C6Corvette 65C6Corvette is offline
Sam,
Get me two… Thanks, Dirk
Old 05-03-2015, 06:28 PM
Old66Tiger Old66Tiger is offline
Good thread. I have a few questions...
I am running an E38 ECU and currently have it set up in discrete mode with a pair of spal fans. I understand that programming is required to switch to PWM mode. I also understand that a binary or trinary switch is required to control the vintage air compressor for over or under pressure conditions. My question surrounds the need for a high pressure signal from the a.c. system to kick the fans into high speed. Is it possible to let the trinary switch send a ground signal to the ECU to send the fans to high speed when the a.c. system requires it? I have an a.c. input from the speartech harness for an a.c. input. Otherwise I will need to wire in a second switch into the #6 line between the condenser and the evap.
Old 05-04-2015, 06:45 AM
samckitt's Avatar
Originally Posted by 65C6Corvette View Post
Sam,
Dirk, Not 100% if/when I will order them. If there is enough interest, i will, & I will let you know.
Scot
86 Monte SS
LS2/T56 Magnum
