Old 09-13-2006, 07:40 PM
GBodyGMachine's Avatar
GBodyGMachine GBodyGMachine is offline
Default G-Body's, Wheel Fitment
I am trying to figure out the widest wheels I can run front and rear. It is kinda hard to measure since my car is torn apart and rideheight is not yet set.
I am going with 18's. I have a frame notch in the rear, and tubular UCA's and LCA's in the front.
HOW WIDE?
Jeff
84 Regal Project GBodyGMachine
[SIGPIC][/SIGPIC]
Old 09-14-2006, 02:16 AM
McssGmachine's Avatar
McssGmachine McssGmachine is offline
Jeff, I think the most your going to get up front is 8 1/2 and the rear with a frame notch is 10 maybe 11" in the rear. John Bzdel did a frame notch on his Monte and has a 10" wheel in the rear of his car. Do you get on any of the G-body sites?
BRIAN WEST
Old 09-14-2006, 05:06 AM
I have not yet, do you have any links?
Jeff
[SIGPIC][/SIGPIC]
Old 09-14-2006, 12:18 PM
I'm on these two sites
www.montecarloss.com
www.maliburacing.com
There's a ton of info on frame notch's and wheel fitments!
Also, Give www.groupawheels.com a call. I have the simmons wheels and they hooked me up with 18x8fr and 18x9.5r with no rub!
BRIAN WEST
Old 09-14-2006, 05:01 PM
Hydratech®'s Avatar
Supporting Manufacturer
HydratechBraking.com
Lightbulb
We have found that we can stuff 15 x 10 on 4.5" backspace into our '86 - '88 Olds 442 G bodies without ANY rubbing! Rims in use are the Wheel Vintiques Olds Rallye Repro SSII Type and the tire sizes used are 245 60 15's, with 26.5" height, 9.64" section width, and 5.78" sidewall.
Here is a great resource for translating the tire sizes:
http://www.americanracing.com/techce...Calculator.htm
With this resource, you should be able to nail down your 18's just right. The Extreme Plus 14" Baer 6 Piston system we will be installing sometime soon had me recalc for 18's, and I came up with 245 45 18, which provides a 26.6" height, 9.64" section width, and 4.34" sidewall.
If you want to see what this looks like in motion, we have action vids on our 'site - check 'em out and see what you think about the look with these size wheels / tires.
http://www.hydratechbraking.com/mult...os/movie_5.WMV
http://www.hydratechbraking.com/mult...os/movie_6.WMV
Founder / Master Engineer
Hydratech Braking Systems ®
Old 09-14-2006, 06:38 PM
Thanks for that website,
It helped alot
JEff
[SIGPIC][/SIGPIC]
Old 09-20-2006, 09:31 AM
jb@ridetech jb@ridetech is offline
I have 275/40/17 all the way around on my 85 monte
Old 09-20-2006, 03:41 PM
What size wheels are you running with what Backspacing?
JEff
[SIGPIC][/SIGPIC]
Old 09-22-2006, 11:06 AM
Rubes Rubes is offline
On my 83 Malibu (wagon, with lowering springs) I got 18x9 w/4.5BS on the rear w/275-40-18 tires. clearance to the frame is just 'bout 1/4" and I had to roll the fender lips. You can probably go with a wider wheel, but in my opinion any wider tire would be a problem (unless you completely cut out the lip, then maybe you can get a 285). This is without a notch though.
On the front (bell tech 2" droped spindles) I went 17x7 w/4"BS (max with the droped spindles) and 245-45-17 tires. This rubs the inner fender well even when tapping the brakes, and can hardly turn the wheel. So I say this setup is definatley a no go. A 5"BS should be OK, but it wouldnt work with the dropped spindles.
Do youself a favor, and dont take anyone elses measrements as a guarantee. Measure your own setup.
Old 09-23-2006, 03:04 PM
Thanks for the advise.
JEff
[SIGPIC][/SIGPIC]
