This is the front suspension on the C10. the front cross member will be just about identical. the control arms will change in width to narrow the WMS to the required Camaro width of 60" (plus brake hats) we did this because it makes the suspension work a bit better. So at least you can see roughly what it will look like.
The Camaro will probably use a Sweet MFG rack (waiting for a sample to test fit) which will be WAY better than most others available. This will handle 315 front tires in any application and last.
The splined sway bar will be available in multiple rates from 570lb for the street to 1250lb for a big road course.
obviously the sway bar is not installed on this frame yet. Monday.
