Old 05-06-2015, 05:14 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Oh Snap! You've made some awesome progress the last few months! Looking good!!
Curtis
Old 05-06-2015, 08:50 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Thumbs up
Car is coming along nicely......lots of great fab work! The wheels are perfect for the car...
Old 05-26-2015, 09:35 AM
Tuske427's Avatar
Tuske427 Tuske427 is offline
small updates... received my driveshaft which is quite pretty, imo, and a shame that it's buried underneath the car. I also hooked the battery up this weekend and started testing the wiring. I had a few bugs (to be expected) and got most of them fixed. The real bummer is the car wouldn't start. After getting a little help it turns out I plumbed the fuel lines/ regulator all wrong (resulting in way too much fuel pressure) and need to add a return line after all. So parts are ordered and I'll be doing some revisions over the next couple of weeks. Live n learn. Stay tuned.
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 05-31-2015, 09:46 PM
Tuske427's Avatar
Default Finally.... it runs
After plumbing in a return line to get the fuel pressure right, and discovering that I had the 12v switched power line hooked up to a terminal that didn't have power when the key was in "start" it now runs. I even drove it, too. Next is to get an alignment and I ordered some new mufflers that are quieter as I want my wife to ride in this, ha ha
Old 06-01-2015, 06:07 AM
Evan Iroc-Z Evan Iroc-Z is offline
Nicely done!
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 06-02-2015, 05:41 PM
Ernie W Ernie W is offline
Very nice build. I thought the pics looked familiar, seen them over on HWC. Glad I got to see more pics of the build.
Old 06-14-2015, 08:28 PM
Tuske427's Avatar
Well, this weekend was a waste of my time. I spent most of it installing my "advance keys" keyless ignition and alarm, and the last couple of hours ripping it all back out. What a POS product. don't waste your money on it. From the instructions being inconsistent at best (at least 4 different errors) to incomplete instructions (had to "learn some things" it doesn't state in in the instructions) to the unit just not working (couldn't get my car to start with it, also couldn't exit out of 3 modes that just kept cycling back n forth- armed, alarm itself- door lock delay function). This is my nice evaluation of it. I will be a bit more thorough with them. guess I'll go back to what I know works- a simple ignition.
