Old 06-04-2015, 07:10 PM
Looks as streetable as a Prius.
At this rate, you'll need to tear it back down and re-lube it. hahahaha
Old 06-04-2015, 08:29 PM
fleetus macmullitz's Avatar
Dyno line graph...
Old 06-04-2015, 08:44 PM
I hope I have a torque curve like that with my stroker.
Old 06-04-2015, 09:11 PM
carbuff's Avatar
carbuff carbuff is offline
And replace those valve springs if the engine hasn't been turned over in a while. Ask me how I learned that lesson.
Old 06-05-2015, 12:28 AM
Originally Posted by Chad-1stGen View Post
ha ha ha. Poor Badmotofinger is the punching bag of Lat-g.
Funny that your dyno graph practically starts at 4k rpm. Because racecar...
It is a punching bag... and well deserved eh.
Starts at 3900 because dyno operator likes to go easy on his dyno, that's all.
I'd be willing to bet this thing makes very respectable torque well below that 3900 number.
437 inches and a cam that's really not that rowdy. I am leaving a ton of power on the table with the heads on this thing due to mild cam and low rocker ratio (1.7) vs your average SB2.2 headed engine.
#becausecubicinchesandmildcam
I know what yer sayin' Chad, but graph does look flat @ 4k and over 500 ft/lbs. I think he'll have plenty of grunt. Plus DG's a down low kinda guy.
Bad Ron, are you actually in support of me here? Kinda? On the down low?
Todd, always the bearer of good news.
Dyno line graph...
Newman!
Nothing like cubes to bring a power band down to the left.
My apologies that you bought a used motor to start with and never touched it before installing.
In all seriousness, I can't recall the specs of yours, but mine has pretty mild spring pressures considering the parts list. I hope this serves me well in the interim and in the longer term.
Old 06-05-2015, 02:40 AM
Hey Chad.... because racecar here as well?
Wait... don't you have a Mast LS too?
Old 06-05-2015, 10:58 AM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
First, I will take Hobaugh's LS7 anytime over my motor. That said, here is my dyno graph...
Note that I do have more torque at 3,600 rpm...
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 06-05-2015, 11:05 AM
Both of those Mast curves look sweet. I am gonna go out on a limb and say all 3 of these engines are/will be a hoot to drive.
In before Sieg asks me what my projected MPG will be....
Old 06-05-2015, 11:23 AM
Sieg's Avatar
Sieg Sieg is offline
David - Keyword: Projected
I hope I'm still alive to see the actual.
carbuff's Avatar
Actually it wasn't used, it had just been sitting for a while. I bought it from the original build shop. But I'd bet those springs had been in the same position for, oh, 5 years or so. And they were beehives, not exactly a high-pressure spring rate on those...
Go put a long wrench on that crank snout and turn it over once in a while.
