Old 06-10-2015, 09:47 AM
ironworks's Avatar
Originally Posted by dhutton View Post
I think the angle on the trim is determined by the draft angles of the casting. Not too much that can be done to avoid that sort of thing.
There is nothing a welder and some talent cant fix.
Old 06-10-2015, 10:12 AM
dhutton dhutton is offline
I've got the welder but come up short on the other ingredient. No shortage of that on your team for sure.
Old 06-10-2015, 04:09 PM
THEY NEVER EVER FIT - as in EVER.... from the factory.... or from the aftermarket. Cut to cure. End of story. Big dollar cars make that in brass.... slim it down a bit - and make it fit like it's supposed to. '56 and '57 are even worse because they use a bigger piece there.
Old 06-11-2015, 07:07 AM
FlameBroiled's Avatar
FlameBroiled FlameBroiled is offline
"Cut Modify Replate".... sounds like a TV show Dan Woods would host??
www.Eyekandykustoms.com
Old 06-12-2015, 12:54 PM
ironworks's Avatar
Time to let this girl dry for the weekend.
Old 06-15-2015, 05:55 AM
ironworks's Avatar
I have had a few inquiries as to how we went about painting the engine and the aluminum parts like the radiator.
With the radiator and aluminum parts we typically send out the part to be powder coated with some kind of primer. This way they blast the tanks or aluminum parts and then coat the aluminum parts with a primer that is baked on. We have found this to work the best. The obviously don't blast the fins of those come back still clean. But you can do the surround and the tanks on things like radiators, and AC condensors. We also do it on anything smooth that is aluminum as we feel the "BITE" of the primer is better with the blasting and heat for the part with primer. We then stack any needed body work on top. Here are some parts we had blasted and primed that I have pictures of.
Here it is with body work on a 2nd coat of epoxy primer. We are letting the body fill dry before sanding.
You can see the top billet aluminum piece in primer. We really shouldn't have any body work on a billet part.
Now the unpainted fins of the Condensor or Radiator in this project will get sprayed with Krylon to keep the cooling capacity to the highest level with the thickest paint. I had a guy at a radiator shop once tell me they cool better in black spray paint, not sure I believe him. But there is nothing worse then seeing aluminum fins through the grille opening of a car.
Now the engine and manifold parts go through the long deburring process. They are then shot in epoxy primer. The primer is given a good couple days to fully dry and since we are not body working the engine we shoot a minimum coat of sealer and the regular base coat clear. And really just enough to cover the engine.
I help that answers your questions.
Old 06-15-2015, 10:58 AM
It came out really nice. Roger is there a clear that can be used over the aluminum by its self just to make the engine easier to keep clean?
Old 06-15-2015, 11:15 AM
ironworks's Avatar
If you mean over the polish aluminum, I'm sure there is. But we wont have much polished or exposed aluminum on this car.
They have some clear powder coat for polished wheels
Old 06-15-2015, 12:01 PM
windycitychev windycitychev is offline
It's awesome that it's finally getting some color but damn what a shame it looked sweet bare metal.
R. Roman
Old 06-15-2015, 09:46 PM
Darrell Darrell is offline
🍊🍊🍊🍊🍊🍊🍊🍊🍊 can't wait to see some ORANGE paint on Gregs fiddy five
Darrell / ZL1 Nova
