Originally Posted by 69MyWay
I have the stock LT1 bellhousing that is my understanding I can bolt to the Mark IV BB and use the conversion flywheel - then keep all the other LT1 stuff...
I'm curious about what you have here...and also the heads.
Doesn't the LT1 bell housing put the transmission at a strange angle? The bell housing I have is specifically for a T-56. I also have an adapter where you can run a standard throw out bearing and fork/z bar set up with the T-56.
The heads are repairable. I have the springs, stainless valves and retainers.
