Old 07-08-2015, 03:58 PM
Trevor @ Tx Speed Trevor @ Tx Speed is offline
The GMPP harness and ECM aren't junk by any means, but the harness will require quite a bit of work to make it look good. GM builds the harness with a LOT of extra length on all of the sensors, so you'll spend days trimming it to look right. Both PSI and Speartech could set you up if you want to go with a custom harness. A custom harness would be something to consider if you're looking to run an electronically-controlled automatic trans. The GMPP kit isn't setup to control a transmission, so you'd have to buy an expensive stand-alone controller for it. That's where a custom harness and ECM can save you some money.
Trevor
Texas Speed & Performance
- '61 Chevy Parkwood 9-Passenger Wagon: Currently Under the Knife : TSP 750 HP 6.2L LSA Engine : Roadster Shop Fast Track Chassis : Mini Tubbed
- '69 Camaro Convertible: TSP 700 HP 6.2L Supercharged LSA Turn-Key Engine : T-56 Trans
- '69 Camaro Project: TSP 700 HP 6.2L Supercharged LSA Turn-Key Engine : T-56 Trans
- '55 Chevy Bel Air: TSP LS3 376 CID Turn-Key Engine : 4L60E : Art Morrison Chassis : Fikse FM5 19" Wheels : Vintage Air
Old 07-09-2015, 05:53 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Trevor
The OP has a 5 speed Tremec. No reason to spend a dime on a custom harness.
The long GMPP sensor wires can easily be shortened by pulling of the split wrap folding the wires to desired length and wrapping with nylon braid. You can do them all in an hour most.
Then it's just a matter of strategically placing the ECM and fuse box and tucking the excess cable into the pass side inner fender.
Can all be done in a day including beer breaks.
Old 07-09-2015, 10:38 AM
BTW, where is the OP? wondering what direction he went.
Old 07-09-2015, 11:01 AM
Ron in SoCal's Avatar
I have a brand new PSI LS3 / T56 magnum harness on the shelf if you need it.
Ron in SoCal
69 Camaro in progress
Old 07-09-2015, 03:47 PM
I didn't see that on your web site Ron?
Whats my dealer price?
Old 07-09-2015, 01:48 PM
I agree that it will work. But, the number one complaint we get from customers with the GMPP harness is the extra length that requires trimming to make it look good. Most of our customers don't want to trim their new harness and/or don't trust themselves to do it. We had a customer order a custom harness last week that returned his GMPP harness. To each his own.
Old 07-09-2015, 05:30 PM
Vega$69's Avatar
You don't need to shorten, cut or re pin to do the job.
This is my new build in progress. The fuse box is mounted behind the pass headlight and all wire bundles are securely tucked in the inner fender along with the AC and heater hoses.
The sensor wires will be folded into power braid to the proper length
Old 10-03-2015, 09:24 AM
droptop 63 droptop 63 is offline
Beautiful detail. My problem is space under the dash on a 63 nova once you try to make the Vintage Air box fit in the same space on the firewall. Any suggestions??
Old 11-14-2015, 05:53 PM
randy randy is offline
my harness is complete and i second this. Hardest part is finding room to mount the fuse box and ecm
Old 11-16-2015, 03:01 PM
Revved's Avatar
Revved Revved is offline
Getting ready to start my first LS376/4L65E / Detroit Speed Swap into an 80 Trans am... I've got the whole GMPP Package and I'm looking at those miles of wires and getting my solder and shrink wrap ready!!
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
