Old 08-14-2015, 09:34 AM
syborg tt's Avatar
I will just leave this here.
marty-mj
Old 08-14-2015, 10:50 AM
Evan Iroc-Z Evan Iroc-Z is offline
Numbers?
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 08-14-2015, 01:16 PM
syborg tt's Avatar
Originally Posted by Evan Iroc-Z View Post
Numbers?
493 Torque & 534hp at the wheels on a very conservative street tune.
marty-mj
Old 08-14-2015, 08:01 PM
glassman's Avatar
glassman glassman is offline
Thats one bad-a stingy bee ya got there.....
Mike
Old 08-15-2015, 11:44 AM
awr68's Avatar
awr68 awr68 is offline
Marty, just getting up to date on this build.
Great looking car! Great plan and execution! Love it! Awesome upgrades and numbers! And as always props for using your cars!
Tony
'68 Camaro
Old 08-17-2015, 12:58 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
Sounds good!
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 08-18-2015, 06:41 AM
syborg tt's Avatar
Thank you very much
I put a lot of time and thought into the Carbon Fiber update and want to keep the car simple looking. I looked at the new ZO6 for inspiration and also worked with Pete at Showtime Automotive and together we came up with a plan to get the car to where it is today.
Originally Posted by bonecrrusher View Post
Sounds good!
Odd the local Police don't seem to agree
Next up will be to finish the interior upgrades to include the Recaro Seats, 1le Shifter, Suede Shifter Boot & Handle.
... and possible the Harness Bar and 4 Point Restraints. (track use only)
marty-mj
Old 08-18-2015, 07:04 AM
Payton King's Avatar
You know that I like yellow! Car is looking and sounding awesome, how does it drive?
Old 08-18-2015, 08:38 AM
syborg tt's Avatar
The original SLP tune was nice but it would hunt at idle. I asked the guys at Speed Inc for a "Street Tune" and that is exactly what they gave me and the car just drives incredible.
ps I will never turn Traction Control off again because it breaks the tires loose going into 4th gear which is enough to scare the **** out of you.
marty-mj
Old 08-18-2015, 09:23 AM
[QUOTE=syborg tt;61407
I will never turn Traction Control off again because it breaks the tires loose going into 4th gear which is enough to scare the **** out of you.[/QUOTE]
I guess when we look for more HP this goes under be careful what you wish for, but in a good way.
The car looks gret Marty.
