Old 08-23-2015, 11:15 AM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Wow that is terrible. I might look elsewhere for a radiator
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 08-26-2015, 06:14 AM
Interceptor5588's Avatar
Interceptor5588 Interceptor5588 is offline
I've been running a Champion 2-row in my 92 Firebird track day car for 3 years -- no issues ever. Slightly taller than stock so cover plate tilted a bit.
70 GTO
92 Formula
Old 08-26-2015, 11:53 AM
70TWO NOVA's Avatar
Thank you for your input, it seems there have been a lot of good experiences with them as well. I think with any part there are going to be those who have a bad experience and they are the ones that are most vocal. I think I am leaning toward Champion now. So hard to chose!
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 08-26-2015, 01:38 PM
GrabberGT's Avatar
Spend the dough on a quality cooling system. I have champion and may now know why my car always seams to run on the hotter side. I've been fighting heat for a while. It does OK but hits 220+ pretty quick with autocross runs being as frequent as 1 every 5 minutes. 10 minutes on the road course in 85* temps gets above 220. Same temp issues on the hwy in hundred degree heat with the AC on. Its bearable but I would like it to be cooler. Im running a MARK VIII fan as well.
Chris
Its not a Vega!!!!
Old 08-26-2015, 10:24 PM
dale68z dale68z is offline
I still have my old champion radiator. You can have it. It had less than 3 months on it. It is like brand new, except I cut the tanks off. You can fab up some tanks and weld it back together.
Free Free Free
I have a friend with the same champion radiator as I have. His is a couple of years old. It has a small leak. Maybe you can get both and combine them together to make one.
Old 08-27-2015, 07:41 AM
70TWO NOVA's Avatar
Thank you but I just bought a new one last night. I figured I would give Champion a try and see what happens. Unfortunatley I dont have the budget for an $800 radiator so I will take my chances and get my car back on the road.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 08-27-2015, 07:35 PM
The griffin I bought was $300. Works great. From Summit.
Like I said, the champion worked well on the street.
