Old 09-01-2015, 08:56 PM
Jr's Avatar
Jr Jr is offline
Default 9" and 3rd member
Quick question,
If I go with a complete 3rd member with a true trac, do I need to worry about setting anything up...for example, backlash or gears howling
Old 09-02-2015, 08:21 AM
Ron Sutton's Avatar
Originally Posted by Jr View Post
Quick question,
I "want" to say No ... as long as you work with a knowledgeable rear end set up source. But the reality is, getting gears are quiet is more of a crap shoot these days, since the manufacturing sources are all over the map.
All the rear ends guys I've worked with tell me that one set this week is great & the set the next week is noisy. Some of that has to do with which plant made them. But even from manufacturing plants know for good quality, the error rate is higher these days.
So my suggestion is, go with the most reputable source you know ... not the cheapest. I would ask several sources which brand they've had the best luck with ... in the specific gear ratio you're planning to run. And if it makes noise, don't attack their skills, realize it is probably the gear source. Unfortunately ... replacing the gear to get a quieter one will be on you.
Ron Sutton Race Technology
Old 09-02-2015, 11:52 AM
Just put louder mufflers on it so you don't hear it.
Old 09-02-2015, 12:10 PM
wiedemab's Avatar
wiedemab wiedemab is offline
REM polishing help?
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 09-02-2015, 03:17 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Originally Posted by wiedemab View Post
REM polishing help?
REM treatment is known to help with noise. Good info on this web page.
http://www.procryo.com/RemGears.html
This is my new setup with REM treated gears.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 09-02-2015, 11:15 PM
Jr's Avatar
Jr Jr is offline
Guys,
Thanks for advice. I appreciate it.
Old 09-03-2015, 02:52 AM
71RS/SS396's Avatar
I've had very good luck with Ford gears being quiet. C&R Racing can build you a 3rd member with REM finished Ford gears.
Old 09-03-2015, 08:33 PM
Jr's Avatar
Jr Jr is offline
I ended up getting a strange 3rd member with true trac. I ordered the double lapped ring and pinion ( currently this is what's popular for quiet operation) from Dutchman.
Old 09-04-2015, 04:51 AM
69x22's Avatar
69x22 69x22 is offline
I bought a used Nodular Iron 3rd member with 3.50 Ford gears. Added a 31 spline trutrac, 1350 yolk and new bearings. Hopefully it will be quiet when it is done.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 09-04-2015, 04:52 AM
69x22's Avatar
Yoke...
1957 Chevy 454LSX
