Old 09-03-2015, 06:17 PM
Default Need these fittings
Hi I have a canton remote oil filter adapter on my LSA motor and I need some fittings like the ones in the picture below, but in this size (1-1/16" -12 AN oil inlet and outlet ports ) Anyone have an idea where to look? Canton only shows two short ones, I would like to get the set like this
These are the ports on the Canton adapter. They are as big as they look.
Old 09-03-2015, 07:06 PM
MeanMike MeanMike is offline
Peterson sells extended pipe to AN fittings like that. Give them a call.
http://www.petersonfluidsys.com/engine_oil.html
Old 09-03-2015, 07:32 PM
Thanks Mike I'll check.
Old 09-04-2015, 12:03 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
You can also try XRP, Inc. Rodger at Ironworks is a dealer for them and has always been willing to help me, even though it's probably not even worth his time.
Erik
69 Camaro
Old 09-04-2015, 02:20 PM
Thanks.
