Old 09-08-2015, 08:45 PM
Novacaine's Avatar
Novacaine Novacaine is offline
Default 70 Nova Reboot...
It seems like it's been forever since I've posted up anything on my car. So it just so happens that it's almost been that long. Shortly after my last update post about the car something called life accompanied by his second cousin crappy luck the car got put on hold. So after a few years of ain't know telling how many people (locally) asking me when you going to finish your car or what you want or are you ready to sell it yet. I DON'T THINK SO!!! I ain't no quitter! Ok now that's off my chest. The car got put in storage for a while. Now it's being revisited and updated with some more modern goodies. Today I ordered a four link rear setup from Matt at MCB. He was very knowledgeable and helped me out with some different options that I was considering. THANK YOU very much Matt! So plans are now to ditch the leaf spring setup and replace with the RideTech four link setup and keep the nine inch rearend. The near future plans for the front is to keep the factory subframe and replace the narrowed tubular A-arms with two inch drop spindles with wilwood brakes. That will be replaced with RideTech front tubular A-arms, Spindle and Tru-Turn steering. Then the plans are to update the brakes. After all that is done and it's back on the ground the big block will be coming out and be replaced with a LS power plant and as far as a transmission goes I'm still thinking about that one. Trying to decide between a 5 or 6 speed or a 6L80E. So anyways enough for now I guess and glad to be back and looking forward to NO set backs this time around. Full steam ahead!
Project Novacaine
Old 09-09-2015, 10:26 AM
WSSix WSSix is online now
Good luck!
Old 09-09-2015, 10:49 AM
you will be very happy with your choices.
We just put a 71 Nova together with the same menu. Big block and all. Customer loves the way it feels and says it drives like a new car. Smooth and sharp. His words.
We went with a Magnum t-56 from American Powertrain. Shifts smooth and with the Lokar/Goolsby series shifter arm, its very comfortable to row the gears.
Make sure you post pictures and document the work.
Old 09-09-2015, 12:48 PM
Novacaine's Avatar
Vince what did you have to do to the tunnel to get the T-56 to fit? Hoping that works out. Thanks for the info.
Project Novacaine
Old 06-18-2019, 08:33 AM
CCS's Avatar
CCS CCS is offline
Smile
... The near future plans for the front is to keep the factory subframe and replace the narrowed tubular A-arms with two inch drop spindles with wilwood brakes. ...
Hi, somebody do it??
factory subframe
Tubular A-arms
2" drop spindles
Please, tell me if you... Thanks.
1972 Chevy Nova
4 door sedan
350 sbc, TH350
Still stock rearend and suspension.
15" Ridler wheels
