Old 09-30-2015, 03:14 PM
TomM's Avatar
TomM TomM is offline
Originally Posted by Vega$69 View Post
The problem I ran into with the fittings listed is the AN hose end hit the PS pulley.
I went with the Turn One Extended O-Ring fitting.
Attachment 55764
http://www.turnone-steering.com/#!on...egory=12459196
Yeah, you are right, just checked, the -AN fitting will hit the pulley, going to have to do the 50 dollar turn one fitting....go figure, sooooo thanks anyway Andrew....knew it wouldn't be that easy...
T,
Old 10-02-2015, 09:42 AM
andrewb70's Avatar
T,
No worries. I've had this fitting banging around my tool box for 7 years, and if you were able to use it, then it would have found a home.
Andrew
Old 10-03-2015, 01:50 PM
Hydratech®'s Avatar
Supporting Manufacturer
HydratechBraking.com
Arrow Alternate options
Any of you that have installed a Hydratech hydraulic brake assist system have seen the neat trick we use first hand, and that is the installation of one of our supplied seat inserts (HBS9106):
http://www.hydratechbraking.com/hose...AB01C0112E3750
This will then allow you to run a tight clearance direct fit 90 degree male hose end such as this Aeroquip FBM1144:
http://www.hydratechbraking.com/hose...DAB61B013131F0
16 X 1.5 is close enough to 5/18-18 to make it happen - no cross thread actually occurs.
Or? Go with a low profile banjo fitting:
http://www.hydratechbraking.com/hose...B01C1119272580
The listing shows a set, though we get calls all the time for just the 16 X 1.5 banjo which we do sell individually at $25. I suppose I really should produce a separate web listing where a customer could buy the banjo's individually (though my current list of TO DO is so damn long already, so call Jim to order)...
I dug around in our database and a close up shot of the direct fit male 90 degree hose end installed into a LS / LSA pump did not jump out into my outstretched arms. I know we have some images somewhere...
Anybody got a pic of our system installed using the Aeroquip direct fit FBM1144 with the brass seat insert handy to show the guys? If so, post it up! Or? Maybe I'll remember where the images are and then I'll post up.
Founder / Master Engineer
Hydratech Braking Systems ®
