Old 11-26-2015, 03:50 PM
paulk68 paulk68 is offline
Default 68 camaro on a 18x11?
So I have no rear end ordered yet for my 68 camaro. How will a 18x11 with 5.625 BS look? please my head is spinning with all these numbers. does anyone have this setup. I am going to run 18x9.5 with 5.5 BS on the fronts which ridetech recomends.
Old 11-26-2015, 04:01 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I am assuming the car is mini tubbed. If you dont have the rear end yet, you can select the rim width/backspacing you like. Once tires are installed, mock them up in the wheelwells so there is equal clearance between the tire and the fender lip on the outside, and between the tire & the frame rail on the inside. Then measure the distance between the wheel mounting surfaces of each wheel. Now you have your rear end measurement, less the thickness of your rotors. For the front, need to know what suspension & brakes your are running.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 11-26-2015, 04:06 PM
thank you, yes the car is mini tubbed and i will be running a ridetech 4 link with baer pro + 14" brakes. I am looking for a 4 inch lip so I should be fine with that BS and then just measure my rear?
Old 11-26-2015, 09:03 PM
KPC67's Avatar
KPC67 KPC67 is offline
Yup pick your desired back spacing. Once mocked into place measure the width from wheel mount surface to wheel mount surface. you then subtract the thickness of your rotor hats..... and viola! you will have your rear end width flange to flange. What size of tire do you plan on using?
Kevin Carter
Old 11-27-2015, 05:42 AM
Thanks to everyone who I have reached out to for wheel advice. I was rushing it trying to take advantage of the holiday sales going on. I am just going to hold off do some more research on exactly what I like for looks and rent a measuring tool. thanks all
Old 11-27-2015, 02:45 PM
Musclerodz's Avatar
That will look fine. Plenty of lip.
Mike Redpath
Musclerodz & Customz
facebook page
Old 11-29-2015, 07:05 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Are the wheels you have the final ones you are going to use? Do you have any tires mounted on these wheels? With mini-tubs you can go up to 18x12 with no problem. My wheels are 18x12 5.6"bs and a 57" rear axle width. Your wheels have nearly the same bs so a 57" axle would net you an extra inch clearance between the wheel and fender. If you are sticking with the current 18x11 wheel a 59" axle width would be in the ball park. However, if you think you might go with a wider wheel you will need to plan for that. Now is the time to decide because once you order the axle you are pretty much locked in to the configuration.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 11-29-2015, 08:03 PM
randy randy is offline
I'm running 18x11 on a 315/30/18 for a nice balance. Check out my thread for details.
Old 01-09-2016, 11:03 AM
John510's Avatar
John510 John510 is offline
Heres a 19x12 with 5.5 BS for reference
[SIGPIC][/SIGPIC]
Old 01-09-2016, 11:07 AM
slimjim's Avatar
slimjim slimjim is offline
[URL=http://s527.photobucket.com/user/JohnS510/media/37B30C1E-50EB-496A-BDBD-50AB1BC3CE55-3556-000001E4340AA2C8.jpg.html]
John do you happen to know your measurements for the rear end? I'm using the same size wheel but with a 5.25" backspace
