Old 12-20-2015, 07:46 PM
Bob, does the upper cross piece unbolt or did you cut the top of your core support off?
Old 12-20-2015, 08:35 PM
Panteracer's Avatar
Default Dreamin Ta's
Trey,
Cut it off Going to fab some alum up
and more than likely cut the sides down and use
Aluminum there also. Need to put the glass hood on
to see where things line up
Bob
Old 12-21-2015, 05:28 AM
Originally Posted by andrewb70 View Post
The MSD box still need a cam, crank, and MAP sensors.
There is another option, that some say works better than the MSD.
Andrew
What I meant by no sensors is -- NO O2 sensors......
Old 12-21-2015, 08:27 AM
Panteracer's Avatar
Greg,
Decided at this time to keep the Poncho motor
Figure out the accumulator had an issue and I
am going to change the gear in the car....
So going to lighten things up, do the brakes and run
it for a while to see how it goes
I really do not want to join the jackstand racing team
for a year or more... so baby steps and keep the car running
for now so no Ls
Bob
Old 12-21-2015, 08:33 AM
SMART!!!!!
Too many unused cars around here! LOL
Old 01-04-2016, 02:18 PM
Panteracer's Avatar
Default Dreamin Tas
Finally got back out in the shop and looked at the new
Fiberglass nose from Classic Industries... good to see it has
most of the stock places to bolt things up... I am going
to ditch the heavy main brackets and fab up some alum
pieces with a new alum cross piece... I am going to reuse
the sheetmetal pieces that hold the lights as they are really light
Trying to figure out where the brake ducts will be going
Hope to pickup some alum tomorrow so I can begin the process
Bob
Old 01-05-2016, 07:47 PM
fleetus macmullitz's Avatar
Bob,
Enjoyed seeing all the improvements you're making to the ole beast.
Old 01-06-2016, 08:26 AM
Panteracer's Avatar
Thanks Skip
Did some weighing of things last night
Old Euro type bumper 41.7 lbs
Old upper cross piece 11.7 lbs
Two Big steel bumper supports 7.15 each = 14.3 lbs
So total is 67.7 lbs
New Glass bumper is less than 5 lbs.. misc alum 3-5 lbs
So thinking over 55 lbs off the nose
Need to see the difference on the hood next
Bob
Old 01-06-2016, 09:41 AM
markaaron80 markaaron80 is offline
nice
Old 01-06-2016, 10:41 AM
carbuff's Avatar
carbuff carbuff is offline
Bob,
What upper cross piece are you referring to? In one picture, it looks like you removed the top of the core support... What did I miss?
