Old 12-21-2015, 01:55 PM
phoenixdawg phoenixdawg is offline
Default LS1 with 125k miles and all the electronics for $1300
or I can get a 60k LS2 no manifold or electronics for $2500 are either price reasonable if not, what should be the target?
Neither motor has a mated transmission.
Old 12-21-2015, 02:25 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Is the ls2 aluminum block?
Old 12-21-2015, 02:37 PM
Sideshow Sideshow is offline
All ls2 are aluminum blocks.
Old 12-21-2015, 06:40 PM
Vega$69's Avatar
Yes I understand but lots of sellers list LQ9 and LQ4s as LS2s
That's was the intent of my question
Old 12-21-2015, 11:47 PM
Oh. My bad.
Old 12-22-2015, 06:32 AM
Ls2 is aluminum block
Old 12-24-2015, 08:41 AM
Anyone that buys a USED motor - should expect the expense of having to rebuild it. As long as you factor that in... then it doesn't matter what motor you buy. It's a gamble. If you assume the risk and are prepared for it ($$$) great. If you think you're just going to buy a "cheap" motor and use it as is..... good luck! You might need it.
Old 01-23-2016, 02:09 PM
abadsvt's Avatar
abadsvt abadsvt is offline
Default Ls1 and ls2
sent a pm.
Josh
