Old 12-31-2015, 08:45 AM
dcrider69 dcrider69 is offline
Default Magnum t56 what shifter to use
I have read myself dizzy on the problems with leaks on the white lightening and black jack shifter.
69 with big block, t56 magnum, Quicktime bell, mechanical clutch, most importantly it is a CONSOLE car.
So which shifter is best and do I use the forward or rear mount?
Thanks in advance!
Old 12-31-2015, 03:21 PM
Tim john--- Tim john--- is offline
I have never experienced a leak of any kind with my "Blackjack" shifter. Been very pleased with it. Tim john---
Old 12-31-2015, 07:48 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
I haven't felt all of them but the MGW feels superb is is very well reviewed.
Erik
69 Camaro
Old 12-31-2015, 10:08 PM
Link to said shifter? Works in factory hole with console?
Old 12-31-2015, 11:44 PM
When did mgw start making then for t56 magnum?!?
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-01-2016, 02:47 PM
Ron@HDC's Avatar
Ron@HDC Ron@HDC is offline
We did have a slight issue with leakage on the first generation models of our Blackjack shifter, but this problem was addressed several years back and is no longer a problem. If you have any additional questions, give us a call at 707-535-3030.
Old 02-01-2016, 05:54 PM
randy randy is offline
Is there a noticeable difference between the t56 mag stock shifter and the blackjack one? I'm thinking about buying one
Old 02-01-2016, 11:07 PM
Motobrewmaster's Avatar
Motobrewmaster Motobrewmaster is offline
I have a Hurst Black Jack on my T56 Mag in my 69 Camaro with a stock console. It has been just fine and doesn't leak at all. Fit is perfect and the shift is short and firm. Can't think of anything else I would want. Therefore I recommend it.
Cheers, Brew
69 Camaro Owned since 1984.
Oh and Yes I am a Brewmaster.
Old 02-02-2016, 07:58 PM
conester2013 conester2013 is offline
I went with the white lightning with my t56 magnum...I liked the ability to adjust the spring detent on that one so you can make it tighter or looser to shift. Very well built. I'm installing it now so i don't have any road time yet. I will come April though....
Brian
Old 02-03-2016, 10:22 AM
Ron@HDC's Avatar
The difference between the standard T56 Magnum shifter and the Hurst Blackjack is the build quality and positioning. The Hurst Blackjack shifter is going to be stronger, tighter and more precise when compared to the standard Tremec T56 Magnum shifter. In addition to that, the Blackjack positions the shifter in the factory location for use with a console.
If you have any other questions or would like to order a Hurst Blackjack shifter, give us a call at 707-535-3030.
