Old 09-19-2015, 11:11 PM
rjardy rjardy is offline
Originally Posted by craig510 View Post
Been making some good progress on the bird. Finally finished the metal work from getting rear ended last May. Falcon is stripped down to the OE red oxide primer. Got my JRi's for the pending Mike Maier Inc MOD 2 Rear suspension. My garage paint booth is just about done.
The old girl had 2 full re sprays and at least 3 trips to the body shop. It is time for some new paint and weather stripping.
Repo and NOS trim
Got the body to line up fairly well with the 90's re-chromed bumper.
A gallon of Jaco took it down almost to metal.
JRi's in the front
JRi's for the rear
I just hope I can get it done before the last Optima qualifier in October.
Looks great! I just did a garage re-spray on mine.
Old 01-11-2016, 07:53 PM
DBasher's Avatar
DBasher DBasher is offline
Just checking in Craig, looking forward to hearing about all the newness!
Old 01-11-2016, 08:05 PM
glassman's Avatar
glassman glassman is offline
Mike
Old 02-16-2016, 10:48 AM
ocejo ocejo is offline
Craig, was it ok with autox when you ran the stock gas tank? Just picked up a 62 falcon that needs a new tank.
Old 02-16-2016, 10:55 AM
flomofo flomofo is offline
Default ...
Nice progress, always liked these more than the notch back mustang that came later.
Old 02-16-2016, 01:11 PM
craig510's Avatar
craig510 craig510 is offline
I always had issues with gas leaking out of the cap, it was not too bad, but you would have a stain on the car after a couple of runs. You see it on all the mustangs as well. I never noticed any issue with leaking out of the vent with the stock tank.
The worse part about the stock tank on Falcons is trying to fill the car at the gas station. The shape of the filler causes them to back up and spill out. I never in 16+ years of ownership filled without spilling at least a little on the paint.
Old 02-16-2016, 01:20 PM
great. that may be why the falcon has the vent port next to the filler. the Mustang tank does not.
awesome car by the way!!!
Old 03-16-2016, 07:39 PM
craig510's Avatar
I finished the kitchen remodel, got the garage mostly organized and a bunch of lights up. The unistrut solved the age old problem of how to mount lights under the garage door. It will also help anchor the walls for my spray booth.
Time to get to work!
Old 03-16-2016, 08:15 PM
Sonar Chief's Avatar
Question
That's a great idea there with the unistrut system, where did you get the brackets for the fluorescent lights? I may have to copy this idea!
Michael
Old 03-17-2016, 10:17 AM
craig510's Avatar
Michael
Thanks, I just use the thin unistrut and unistrut nuts and washers to make the brackets. I welded spacers to some of them so they would all be the same height. To attach the lights I used fender washers and sheet metal screws.
