Old 01-16-2016, 06:54 AM
JDODDS187 JDODDS187 is offline
On to the body cart after I came to the conclusion that my sandblaster isn't enough to even get through the seam sealer and most if not all the rusted panels were going to be replaced, I did how ever finish up the sub frame and the under side, I will do the inner part of the quarters once I remove the old quarter panels. and just the rest as I go along, mean while i will use a wire wheel and air sander on the areas that I'm working on as I go.
Got it on the body cart and square and level, then realizes that I'm not at the ride height, was so concerned about square and level that that slipped by......
Back to cutting :
