Old 10-02-2006, 12:01 PM
Lateral-g Moderator
I used an Edelbrock system on my ZZ502 motor and it ran great. 4-5 more mpg and 30-40 more hp. No complaints and customer service was fine to.
Old 10-02-2006, 12:48 PM
camcojb camcojb is online now
Very true, works fine a milder combos. It is somewhat limited in tuning compared to FAST, BS3, Holley, etc., and cannot be run on a forced induction setups. But when tuned correctly it works very well.
Old 10-02-2006, 12:56 PM
Lateral-g Moderator
FAST, BS3 are awesome systems. Especially for guys like Jody that can actually use the system, for an idiot like me -no way!
Old 10-02-2006, 01:22 PM
I'm positive you could learn to tune it Stuart, you're a very smart guy (not that "smarts" have anything to do with it). I enjoy doing my own tuning and as long as I can continue and am not grenading my stuff I'll keep doing it. It is simpler in most cases to find a trusted tuner though.
Old 10-02-2006, 01:29 PM
Lateral-g Moderator
Jody is too modest guys. He can tune with these systems, so call him day or night for tech help. LOL. Jody is the man, lets see some shots of that car of yours someday dude.
Old 10-02-2006, 06:39 PM
Matt H. Matt H. is offline
ok here are my engine specs
477 cid, 11:1 compression, brodix racerite oval port cylinder heads, crane hydraulic roller camshaft (i forgot the exact specs) the engine should be around 520 horsepower, with a stick shift transmission. what would you suggest for that?
Old 10-05-2006, 08:52 PM
between holley and edelbrock
Old 10-09-2006, 04:57 PM
anyone?
Old 10-09-2006, 05:25 PM
tracy's Avatar
tracy tracy is offline
I know you have already rejected this but I would still suggest letting Frank at Prodigy put together a system based on the FAST controller. This is going to be the most flexible setup you can do since you can hand pick, with Frank's help, every component in the system.
Worst case you can find someone local that can tune it for you. Otherwise, I think Frank has access to someone that can help you tune it if that is even necessary.
This is the route I am going with my BBC.
-Tracy
Goodies Speed Shop
Old 10-11-2006, 08:12 PM
im not worried about tuning i know a guy who can tune anything, the reason i decided against FAST was because from what I was told the system is really more than i need and its more sophisticated than i need. i talked to someone at prodigy and they said it was mainly for 800-900+ hp engines and mines gonna be around 520. he told me it would be easier and more practical to go with a holley or edelbrock for what im doing
