Old 01-25-2016, 09:53 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
No burnouts till after 300 miles! Epic. Looks and sounds awesome.
Curtis
Old 01-26-2016, 07:36 AM
Great job, and congrats on getting the car running!
Old 02-22-2016, 02:54 AM
sleepertime's Avatar
sleepertime sleepertime is online now
Post Starting to get dressed up...
Making some progress, I got the AC all vacumed, purged and filled with freon.
I was having issues with leakes.on radiator hoses, but have now got those all corrected.
The small steam vent hose was giving me the most trouble dripping down on the other two hoses making it look like they were the problem.
I was also having an issue with my new Pro 5.0 shifter. I was barely able to get into first gear and reverse, after further looking at the shifter and some go ogling I was able to determine that the GTO T56 that I am using needed the shifter lever swapped out with shorter one from a camaro T56, oh well live and learn.
Got the grill, bumper and headlight trim installed.
It took some digging to figure out this little known fact that the Camaro uses the shorter shifter lever on the left.
My build BRNAGN 1969 camaro SS
Old 02-22-2016, 06:06 AM
SSLance's Avatar
SSLance SSLance is offline
Originally Posted by sleepertime View Post
It's been five years since I started this project. But the first time this car was a project was in 1982 when I was a freshman in California. Many miracles later and here we are!
The first startup...
The first test drive...
RIght on! Congrats on the big step!! Now it's just the little nit picky things to tidy up to finish it up.
Lance
Old 02-28-2016, 06:12 PM
Smile Outside for some pictures...
I had to get it out in the driveway for some more inspiration, so that I could see it at more of a distance than just in the garage.
Old 02-28-2016, 06:57 PM
preston preston is offline
apologies for not perusing your entire thread, but what headlights are those ?
Old 02-29-2016, 03:41 AM
rickpaw rickpaw is offline
Nice looking Camaro. Are you taking it on Power Tour this year?
Tu Ho
Old 02-29-2016, 03:50 PM
Post Updates...
The headlights and bulbs that I ended up using are these types.
The headlights
http://www.ebay.com/itm/7-ROUND-GLAS...item540831bac6
The inside bulbs:
http://www.ebay.com/itm/161614752487...%3AMEBIDX%3AIT
I am not sure if the car will be ready for power tour, I still have a number of critical path's to complete....
Old 03-11-2016, 09:33 AM
Post My first try at a headliner install...
With all of the other stuff that I have tried I thought I would give a try installing my headliner. In the end it wasn't so bad.
With some help of the carefully placed heat gun and my heat lamp while monitoring with a temperature gun, I kept it below 220 degrees.
Old 03-12-2016, 05:06 AM
67machrod 67machrod is offline
Hi Dennis,
Amazing story and awesome car. I live in Houston and work in Channelview some days. Would love to check out your car one of these days!
John
