1968 Camaro Project /roller SW/ California car
Item Location (City/State):Las Vegas, NV 89131
Price: $14,000 obo with all new parts listed now FIRE SALE!! $12,500 for everything!!! FIRM!! SOLD!!
Description:
I have decided to let go on this car and focus on getting my shop built
I had planned on another pro-touring build, but plans / finances changed
I have a nice 68' Camaro that was originally a V8/ powerglide car, PS, no-A/C
The previous owner had the rear quarters replaced (80%) and trunk pan, this is a desert car and still has the original outer wheelwells, original floor pans, front inner wheel wells , Radiator core support w/ radiator, hood latch & support, Cowl panel , firewall heater box (as well as inner heater box and stock controls), original window trim moldings , front & rear bumpers, stock subframe w/ PS box and steering linkage,etc
The car only has surface rust on floor pans with two small spots on drivers front that go through, other than that, no rust
It has both front bucket seats and rear seats, seat belts, auto floor shifter, std floor shift steering column, front and rear original glass, drivers and passenger sides door and quarter glass w/regulators /tracks
set of (4) 15x7 Rallye wheels, 10 bolt rearend w/ mono leafs
the car includes front sheetmetal, all Brand New In Boxes from Classic Industries:
- Right & Left Fenders w/ lower extensions
- Header panel
- Lower Valance Panel
- SS steel Hood
- front and rear spoilers
California Title (old pink from 87' signed over in 95')
can take and send additional pics
BODY:
(New Front sheetmetal has just been bolted on car):
Left and Right side Front Fenders w/ lower extensions
Front Header panel
Front Lower Valance panel
SS steel hood
Rear Spoiler
Front Spoiler
Small Block Fan Shroud W/AC
FUEL SYSTEM:
Fuel Tank Mounting Strips
Fuel Tank Neck
Fuel Tank to Filler Hose
Gas Tank Anti Squeak Inserts
Gas Tank Neck Sleeve
Sending Unit Gasket-small
Sending Unit Locking Ring-small
Fuel Tank Strip Mounting Bolts
Fuel Tank 67-8
SS Camaro Gas Cap
INTERIOR:
Deluxe Steering Wheel Kit
Black Carpet Kit
Blk A-Pillar post pads (pair)
PUI 68 Deluxe Blk Rear Seat Side Panels
Blk Dash Pad
68 Blk Deluxe Front Door Panels
68 Black Houndstooth Cpe Seat Upholstery Cover set
Complete Vintage Air kit for 67-8 Camaro ( minus compressor, going LS engine)
Vintage Floor Mats-Black
68 Tic-Toc-Tach 5500rpm Tachometer Assembly
Blk Package Tray Cover
Blk Headliner Kit
Headliner glue kit
Upholstery Hog Ring Pilers and set of Hog Rings (for seat cover install)
X-Body Black Console Gauge Assembly
68-69 Deluxe Front and Rear Seat Belts (5) complete car kit
Center Horn Cap Mounting Ring
Turn Signal Cams
Center Air Vent Assembly
Window Handle Crank Plate x4
Rubber Seat Back Stopper Kit
Deluxe Inner Door Handles
68 complete interior screw set
Door/Truck/Glove Box Lock Set with Original Keys
Bucket Seat Bracket Covers
68 Deluxe Seat Emblem Kit
FRONT SUSPENSION:
Upper Control Arm Bushings
Lower Control Arm Bushings
Outer Tie Rod Ends
Inner Tie Rods
Stabilizer Link kit
Upper Ball Joints
Lower Ball Joints
ELECTRICAL:
American Autowire Classic Update full car wiring harness kit
Ignition Switch Lock
Ignition Switch
Head Light Switch Assembly
Windshield Wiper Switch
BODY COMPONENTS:
Body Upper Door Jamb Seals
Deluxe Felt Kit With Deluxe Interior
Roof Rail Weather Stripping
Door Frame Weather Stripping
Hood Louver Gasket
68/9 Camaro Deck Emblems
68 350 Front Fender Emblems RH&LH
68 SS Front Fender Emblems
68 Standard center grill
67/8 Speedo cable
Poly body mount bushing kit -black
SS Grill Emblem
Buyer arranges shipping
In Las Vegas, NV
pm/ call/ text (702)677-4085
Here Is The UPDATE Parts list that is available with the car for $12,500 FIRM!! SOLD!!! all new in boxes / packages
Attached Images Attached Images
