Old 02-02-2016, 04:11 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Want to go wider fronts
Guys, going with a new set of wheels and want to get wider 18" wheels for the front. Issue is the current setup as seen below, the issue is the tie rod to steering arm is not going to clear by about 1/2" ... any suggestions ??
I 'believe' I have the shorter steering arms but not certain
Looking at some aftermarket billet arms .. again any suggestions
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 02-02-2016, 08:39 AM
carbuff's Avatar
carbuff carbuff is offline
Is this an application for the RideTech Tru-Turn setup? I haven't researched it myself, but I think they offer a shorter arm and revised steering geometry...
Old 02-02-2016, 09:48 AM
JKnight JKnight is online now
With the Ridetech Tru-Turn you do have to use the Ridetech Spindle to maintain proper geometry. I think the OP is looking to use the ATS spindles he has, so that may be out.
I don't know if it's possible, given geometry and packaging considerations, but a steering arm for the ATS spindle that works with the F-body (not the A-body arm they already make) and provides additional room for the wheel/tire could be a nice offering. I would think it could roughly replicate what James/David P. did to the OneLap factory steering arms to create additional clearance on an ATS spindle/factory subframe application.
Old 02-02-2016, 10:23 AM
Sheck44's Avatar
Jeff, exactly ... Tru Turn will not work with the ATS spindles, and yes I am looking for others with experience with this to chime in on exactly what can be done. There seems to be a few different arm options out there (as per Dave Pozzi) and a aftermarket billet ones too.
I am also waiting to hear back from the guys at Speedtech ...
Steve
73' FJ40 LS - SOLD
911 Hotrod - SOLD
2002 Gated 360
Old 02-02-2016, 12:07 PM
Hi Steve,
I wait to see what Speedtech has since thew new Extreme sub uses the same spindle and with an upgraded steering arm is capable of +7" of back space. If I recall the stock arm on the spindle will only take a 5 3/4" BS.
Old 02-02-2016, 12:28 PM
Id have to say Steve just toss the spindles in the scrap bin....then pick them out and send them my way lol, swinging by DaSilva Friday afternoon...hope to see your car there
Old 02-02-2016, 01:05 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
With a 7" backspace the tie rods may hit the inside of an 18" wheel if you have a stepped lip like Forgeline. Also the issues with a 7" bs is the wheels may hit the arms. You can add a stop on the steering arm but this will cost you steering radius.
Some some things to consider.
Old 02-02-2016, 01:45 PM
Sheck44's Avatar
John, this is exactly what I want to avoid, and looking for steering arm/tie rod options
Steve
73' FJ40 LS - SOLD
911 Hotrod - SOLD
2002 Gated 360
Old 02-02-2016, 01:52 PM
johnnysuede23 johnnysuede23 is offline
I'm not familiar with the ATX spindles however when I was looking around for steering arms to use on my ridetech spindles I found a few that could be made to work. The top one is a regular GM steering arm and the other 2 are made by speedway. They will need some work to fit a GM spindle. They are designed to be used with metric impala spindle they sell, bolt spacing is the same however the bolting surfaces are different and would need to be shimmed, also not sure if they would clear the top of a ball joint stud.
SuedeSpeed.com
Old 02-05-2016, 08:39 PM
mfain mfain is offline
I ended up making my own out of 7075. I am set up for 12.5 inch wheels with 9 inch backspacing.
Pappy
Name:  ATS Spindle.jpg
