Old 02-20-2016, 01:42 AM
paulk68 paulk68 is offline
Default Installing a Mast Oil Pan
Hey Guys, I am getting close to installing my new mast ls oil pan on my crate LS3. has anyone done this swap recently is it pretty straight forward? Can you think of any tips/tricks that you used. My plan was to reuse the oil pan gasket that came on my motor as well as the stock windage tray. Has anyone had any fitment issues using those stock parts? also will my stock dipstick and dipstick tube work as well?
thanks
Old 02-20-2016, 04:19 AM
Tim john--- Tim john--- is offline
My Mast pan was a direct bolt on, no issues at all. My engine is a 2004 GTO LS-1 and that required a different dip stick tube and dip stick in which Mast also provided as an extra cost option. Real pleased with the quality and fit of everything. Tim john---
Old 02-20-2016, 06:52 AM
I just installed one also and no issues. I had to dig up my windage tray nuts that came with my arp kit as my previous pan (Holley 302-1) had a pickup with a single support. Mast has two.
Happy with how it all went together and I did opt for basically every option they had (dipstick and tube, oil cooler, etc)
The pan has some casting flaws I'm not thrilled about but it will be fully functional. Also I wish the port on the back has more space for a sensor or fitting. And drawing of that needs to be updated as the thread identified in the drawing is incorrect.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-20-2016, 06:27 PM
simbad's68 simbad's68 is offline
Default Mast Oil Pan
I just installed one on a LS3. no problems here.
Old 02-22-2016, 04:25 AM
Che70velle's Avatar
Not meaning to hijack' but does the mast pan come with a provision for oil temp gauge sender?
Thanks Dad!!
Old 02-22-2016, 05:04 AM
That was one of my complaints. The port on the back of the filter boss looks like it's made to be adapted for that. But you can't get a fitting over the hardware. I put a button head on it and thinking will work but other than that, it's not really made for a sensor.
I have some pics if you want I can host to show better what I'm talking about.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 03-07-2016, 04:25 PM
RPitts's Avatar
RPitts RPitts is offline
No problems on my LS3 reused my pan gasket. Fits easy with DSE frame.
Rob
Old 03-08-2016, 04:36 PM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Mast pan on my LS3 as well, no problems. Great product.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
