Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Speedtech Performance USA
Old 10-23-2015, 01:37 PM
Track Junky's Avatar
LOL.Sorry Blake. Had to ask. Rear of my car already sits low (23" to panel lip) so i just needed to know. I imagine the clearance issues up front are mostly due to the inner fender well and thats not an issue on my car. I'm running 295's up front on 17x9.5's with 5.5" back space right now with a stock subframe and rubbing is not an issue unless I want to make a 3 point turn.
Regardless, with a little fabrication work anything is possible.
I wont be ordering anytime soon but it's definitely on the list.
Gaetano Cosentino
Old 12-03-2015, 02:08 PM
1965_SS's Avatar
1965_SS 1965_SS is offline
Any updates for doing a 64-67 Chevelle frame?
_________
1965 Chevelle SS
Project Build
Old 12-04-2015, 07:08 AM
Blake Foster's Avatar
NEXT WEEK we will start on the 68-72 frame. I have a 66 here for fit up. but is will probably be later in the year till we can get to it, I have some solid commitments for 567 Chevy and the square body Chevy trucks.
so many models to cover so little time
Blake Foster
www.speedtechperformance.com
Old 02-22-2016, 02:16 PM
Build-It-Break-it's Avatar
Can you guys post up some pics of the steering column/shaft fitment, header clearance etc on the first Gen camaro extreme frame.
Ahmad B
Old 02-23-2016, 11:13 AM
[IMG][/IMG]
this should help
Blake Foster
Old 02-23-2016, 02:49 PM
Thank you Blake. I shortened my GM steering column and wanted to see if it would work and it will.
How long to the new updated rear upper torque arm cross member is released/pics?
Ahmad B
Old 02-24-2016, 11:32 AM
the new Torque arm cross member is in stock. if you are interested I can sell you the plates to install/retrofit into an existing car.
I will try and find a good pic
Blake Foster
Old 02-24-2016, 06:37 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Blake can you PM me a price for the (modification kit?) Please. Thanks
Old 02-24-2016, 06:59 PM
Hey Blake, can you PM pricing as well.
If your able to get pics up as well that be great.
I already welded in the original torque arm upper cross member design but want to see if it would be worth the trouble to cut it out to weld in the newer design.
Ahmad B
Old 02-26-2016, 03:36 PM
[IMG][/IMG]
here you can kind of see how it mounts to the floor.
[IMG][/IMG]
Blake Foster
