Old 03-01-2016, 04:28 PM
MetalWorksClassics's Avatar
MetalWorksClassics MetalWorksClassics is offline
Adding bump stops.
Old 03-04-2016, 08:58 AM
Default Mock up
Mocking up more of the sheet metal for fit as the car was apart when it arrived at the shop.
Old 03-05-2016, 04:11 AM
Nine Ball Nine Ball is offline
Great build, guys. I like the engine choice, too.
Tony
Founder, LS1Tech.com
1969 Camaro SS Convertible | 1970 Chevelle SS 454 | 2006 Viper Coupe | 2014 Viper TA | 2014 Camaro SS 1LE
Online Garage: www.fquick.com/NineBall
Old 03-05-2016, 06:12 AM
DOOM's Avatar
DOOM DOOM is offline
Tony
What he said!!!!
Mario
USCOLLISION
Old 03-07-2016, 01:38 PM
Tony
Thanks guys...yeah we really like working with Butler engines...we put one in a 78 TA that really turned out great...we have another one in inventory for a 65 GTO build as well.
Here is a link to the 78 TA... https://www.youtube.com/watch?v=jOjPShkhnrs
Old 03-07-2016, 06:32 PM
LanceL LanceL is offline
Three questions for you guys? What body mounts do you like to use? On the floor install did you cut the old floor using the new piece as a template or how do you guys like to do it? And it looks like continuous welds for the connectors? Do you not have to skip around and worry about warpage of the metal doing those? Thanks for the help and answers. We all appreciate the pics and knowledge.
Old 03-08-2016, 01:53 PM
Sorry we can't help on the body mounts as they came with the project, we did not order them.
On the floors we cut the bellys out, then sat the new pan in place and traced around it with a marker, then cut the rest of the old pan out...this allowed us to butt weld the new pans in place.
I agree the frame connector welds looks continuous, but we actual did skip around only doing around 5 spots at a time.
Thanks for the questions...take care.
Old 03-08-2016, 05:10 PM
Thanks a lot for the answers. Your car is bad ass. Following for sure.
Old 03-08-2016, 06:04 PM
Centerforce's Avatar
Centerforce Centerforce is offline
Aw we wanted to see a good clutch shot before you put it together!
Did you end up going with a DYAD?
Old 03-09-2016, 01:51 PM
Hey guys...YES we do plan to run a DYAD, but the motor and trans are only at the mock up stage...I will definitely get some good clutch pics of the final install...we've been having great luck with the DYAD sysetem with these high HP engines.
