Old 03-13-2016, 05:31 PM
paulk68 paulk68 is offline
Default Ridetech cradle fitment
So I am test fitting my ridetech 4 link cradle in my 68 Camaro and at first try it is not going so well, when I get the passenger side sitting snug to the rear frame rails the driver side get pulled down away from the rails enough to fit a finger between the frame and the cradle. Have others had such a large gap? Also where do you start to pull it up tight to the rails.
Old 03-14-2016, 06:00 AM
dhutton dhutton is offline
Sometimes you need to take a big hammer to the trunk floor and persuade it up a little where it is contacting the cradle. Sometimes you can push the cradle up with a jack if the car is assembled.
Old 03-14-2016, 09:45 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
What Don said. Keep in mind that these cars are nearly 50 years old and there is no telling how many owners the car has had or if it has been in an accident in the past or what has been thrown into the trunk over the years. If the trunk floor is sagging you need to push it up.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 03-15-2016, 05:05 AM
Thanks guys, I was afraid of that, the floors and truck pan are brand new it is going to hurt me mentally to start beating on them with a hammer.
Old 03-15-2016, 07:31 AM
Is there a preferred technique should I use a wood block along where the bar meets the floor? here is a couple pics
the bad side
Old 03-15-2016, 09:39 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Like the other guys are saying, some clearancing may need to be done to get the cradle all the way forward. Sadly, you see more issues with the new floor pans needing to be clearanced more than the stock ones.
Old 03-16-2016, 12:44 PM
so I spent some more time on this today and it is ugly. I mean i am almost an inch off from one side to the other. Is that normal?? am I really supposed to massage an inch somewhere in the sheat metal? I pulled out my level concerned the rails were off but that is not the case.
Here is the passenger side sitting where it should
And this is the drivers side
please help wish some suggestions. I get needing to go up a little but this is alot i feel.
Old 03-16-2016, 03:45 PM
Just look to see where it is contacting and start relieving it. Not much else you can do. Use a lot of small hits instead of a few big hits.
Keep in mind it's not an inch, it's a half inch or less when you set both sides with the the same gap.
Old 03-16-2016, 05:01 PM
Thank you very much Don going to give it a shot this weekend
Old 03-22-2016, 09:20 AM
Did you get everything put in over the weekend?
