Old 03-17-2016, 02:06 PM
RPitts's Avatar
RPitts RPitts is offline
Default New Ron Davis radiator
Item Location (City/State):Santa Rosa
Price:$1300
Description: only used for mock up never had water in it. Comes with built in recovery tank. Paid around $1600 this has the Sbc or bb hose location. Switching to LS located in Santa Rosa ca. Ask for Rob
Old 03-17-2016, 09:12 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Instead of selling it because the top hose is in a different location why not just get a hose that runs over to that side?
Old 03-17-2016, 09:52 PM
RPitts's Avatar
The intake duct is in the way for any type of piping and I like the port on LS style for steam vent.
Old 03-18-2016, 04:52 AM
jwcarguy jwcarguy is offline
Banned
you could run it like this?
I used my big block radiator for this swap
4" intake tube also
Old 03-18-2016, 09:52 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Run the stream vent to the top of the water pump. Not mine but I did mine real similar
http://s1233.photobucket.com/user/ts...04-12.jpg.html
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 03-18-2016, 10:44 PM
Banned
It would also depend on which water pump you use to run that style setup
The pumps don't always came in on rh/ passenger side
if you look at my pics, I am using a LS3/7 pump with inlet on lh/ drivers side and ran my steam port inline to upper radiator hose
Also, you could always have a radiator shop or fab shop, weld in the -4an male bung at top of tank for steam port
Jeff
Old 03-19-2016, 10:45 AM
RPitts's Avatar
Thanks for the feed back guys. So I've mocked up my intake and you can see how close the upper outlet is to piping. I would love not to have to buy another radiator. Here are some pics of what I'm looki at.
This is my water pump that came with the engine any advice would be great.
Old 03-19-2016, 10:48 AM
Banned
What about running the intake tube to the rh side?
Or is that real estate spoken for?
Old 03-19-2016, 07:48 PM
CamaroAJ's Avatar
Flip that thing upside down and run it to the passenger side like jw said. It'd give you a clean short upper hose.
Old 04-19-2016, 08:27 AM
RPitts's Avatar
Sold. Ended up buying a new correct one but this time I ordered with correct outlets and got an oil cooler!
1968 Camaro LS3
1969 COPO 427
2013 ZL1
